Results 1 to 15 of 23
This is a discussion on Ultimount for your radar detector within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was looking for a solution to permanently wire my radar detector in the car. Also I needed to take ...
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I was looking for a solution to permanently wire my radar detector in the car. Also I needed to take it off when I parked to avoid theft.
    The only solution I found was the Blendmount. But at $89.99 it seemed absurdly expensive. Then I came across this Ultimount. Lets just say for the price of one Blendmount I could get 3 Ultimounts.
    I have not come across a Blendmount so I do not know about its construction & quality.
    The Ultimount is well built from "aircraft grade material" (whatever that means). Latches on to the rear of your rear view mirror. They say it is a universal fit. Separate models are available for the Escorts & Valentines. It comes with an extra set of longer screws if the ones attached do not fit your rear view mirror. As seen in the picture it allows you to raise & lower the detector & rotate it also. So if you adjust the rear view mirror,all you have to do is turn the detector individually in the appropriate direction.
    I have a Valentine & the Ultimount came with an extra windshield mount release bar that costs $10 on the Valentine website.
    Available at external websites.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    Looks terrific actually. Any chance the added weight of the detector will affect the mirror connection? Otherwise, I'm in too, I'm looking it up right now! Thanks!
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    You don't run the pigtail cord, do you? I've got mine mounted with the stock V1 suction mount just above my mirror, just below the black dots. The higher, the better (with a clear view, obviously)
    I prefer to keep my detector as hidden as possible. Mine is mounted "behind" the black dots. I haven't noticed any real signal loss (still does its job for me and my driving), and from outside the car, it's tough to see, even if you're looking for it.
    Aug 2010
    Yonkers/NYC
    I have not noticed any problems with the added weight. The Ultimount weighs just 4 ounces plus the weight of the detector.
    Quote Originally Posted by mcdbrendan View Post
    I will be hard wiring it this weekend. Got the kit.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Dec 2011
    Boulder, CO
    I like stealthyness, but I'd hate myself if I was tagged and had a slow response because of the dots. I'm sure the loss is minimal like you noted, but Mike V noted even the tinted band has an effect.
    You've got me curious, will probably switch mine up and drive past some known spots to see if the response is different. I really like that you can't see your's mounted outside.
    Dec 2011
    Boulder, CO
    Quote Originally Posted by rage-wrx View Post
    So worth it. I'm working up a stealth mute button on the back of my wheel, hope to have it finished up next week sometime.
    Aug 2010
    Yonkers/NYC
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    So can one use the ultimount to mount the detector up and behind the dots also?
    Dec 2011
    Boulder, CO
    Awesome, but you still need the V1 mounted somewhere with good visibility, the mirror only has the concealed display. I'll be adding the concealed display just below my speedo - that's the first place I look anyway.
    Aug 2010
    Yonkers/NYC
    This a good question. Something I thought of after the mention of mounting it high up. The detector would be upside down. Let me go check & I'll let you know.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    I don't like it
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Agh, you're right, the detector would be upside down.
    At what speed are you driving that a slight loss of signal really makes a difference? If you're using your detector properly, by the time you get signal (unless it's 3AM and you're the only car on the road in a long straightaway on the Interstate), you'll be able to slow down to a "don't bother me" speed undetected (e.g., no nose-dive).
    Have I been stopped with my V1 hung there? Yes. Have I ever been stopped due to being lit up? No. The only speeding stops (no violations, though) I've received in almost three years are due to no radar being on, and them observing me at speed. I have yet to experience getting lit up on my V1, I have been able to discretely get back to a reasonable pace so there is no issue, except for the 48/45 stop, but that's BS. Before the detector, my municipality stopped me three times for under five over the limit (once with), so it's not like I live in a lenient area; they love their traffic citation revenue.
    A detector shouldn't prevent you from getting tickets; it should be a tool you use to avoid them. That's the biggest problem I see with people when they get a detector. They believe they are free to drive like a jackass, which isn't the case at all.
    Dec 2011
    Boulder, CO
    Agreed on every point. I want the best signal simply because I like knowing exactly what's going. Not a single speeding ticket on my record.
