Results 1 to 15 of 15
This is a discussion on My Radar Detector Hardwired within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Awesome Blendmount Attachment Re-wired Smartcord w/working button and lights. hardwired with smartcord re-wired and attached with a blendmount...
    May 2012
    Edmonton, AB
    Awesome Blendmount AttachmentClick image for larger version.
ID:	105679Click image for larger version.
ID:	105680Click image for larger version.
ID:	105681Re-wired Smartcord w/working button and lights.Click image for larger version.
ID:	105682Click image for larger version.
ID:	105683Click image for larger version.
ID:	105684Click image for larger version.
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Very clean install! Good job!
    My "Build" Thread!
    2006 WRX TR
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Very nice job. Just as I was thinking of doing the same thing.
    +1 How did you install the mute button.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    May 2012
    Edmonton, AB
ID:	105690Click image for larger version.
ID:	105691Click image for larger version.
ID:	105692Click image for larger version.
ID:	105693Click image for larger version.
ID:	105694Click image for larger version.
ID:	105695Click image for larger version.
ID:	105696#1 Take apart the adapter with the mute button and lights(when you do this, you can also salvage the sticker, I then put it on a bank card until i was ready to stick it back on) then gently take out the circuit board from inside the adapter.
    #2 Get out your drill and drill a hole for the mute button, then two smaller holes for the lights.
    #3 Carefully run the circuit board around the map light wires and mount it so that the button still works
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That's perfect! That's exactly what I want to do on one of my button blanks
    May 2010
    Pittsburgh, PA
    Would the mount fit if it was inverted? I already feel the mirror is in my view. If it was above or more behind it though, I'd be real happy.
    2011 STi Build Log
    May 2012
    Edmonton, AB
    I don't think so, it only goes on the way you see it.
    Registered User Ryouko's Avatar
    Mar 2012
    South Jersey
    wow, that is a good looking install. You have me curious about how inconvenient it is to hit the mute button. I have mine in the I/C water spray button blank. So it is right next to the E-brake for me.
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Ryouko View Post
    On your car that's the heated seat blanks.
    IC Sprayer blank is next to the fog lights
    May 2012
    Edmonton, AB
    it's not horrible, of course i never thought about using the blank beside the foglight(which would've been a little bit more tricky to wire). that maplight area was really easy to mount the circuit board that the mute button and lights are attached to.
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Repositioning the whole board to a switch blank would be as simple as cutting the 3 wires in the smart cord, adding whatever length needed then running the whole board to what ever location you wanted. And of course hiding the wires behind whichever trim you choose.
    You could separate the switch from the board if you wanted by un-soldering the connections then soldering on wires of what ever length need to get the switch where you wanted it, with a little ingenuity it wouldn't be hard to mount just the switch to a blank. Then you could still have the lights in the ceiling which is pretty cool and you would have convenient placement. Although you wouldn't have the clean look of the sticker right there with everything.
    Mostly just thinking out loud as I have been putting a lot of thought into this lately haha
    Mar 2012
    South Jersey
    Oh, is the IC sprayer there on the '05? I'm pretty sure I remember seeing it there on my brother's car, and just assumed they didn't move it.
    May 2012
    Edmonton, AB
    this is true, and in all honesty i got rushed(kids and all) and the map light area was the easiest/best place for me. if i ever buy a straight hardwire cord, i will most likely put that button in a different spot, like a blank.
    Registered User carnevino's Avatar
    Mar 2012
    Vegas baby!
    I REALLY like how you did the Smartcord, going to have to do that one tomorrow. I routed my wire through the window shade assembly. Click image for larger version.
ID:	105917Click image for larger version.
ID:	105918Click image for larger version.
