Results 1 to 14 of 14
This is a discussion on Gauges? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've already decided to install a clock replacement triple gauge pod and put in a boost gauge but what other ...
    Registered User Kevindood's Avatar
    Jun 2011
    Norfolk, VA
    Gauges?
    I've already decided to install a clock replacement triple gauge pod and put in a boost gauge but what other two should I install? Whats the best gauges for the money and where can I get the cheapest gauges online? I know there's a lot of merchants on this site, so any help would be appreciated.
    May 2010
    Pittsburgh, PA
    Depends on if you'll be doing your own tuning in my opinion.
    I'd add oil pressure as one of them. It's a nice flag to when anything is going wrong. The other one is your call.
    2011 STi Build Log
    Jun 2011
    Norfolk, VA
    At first I'm not going to do my own tuning, but hopefully I'll get there. Thanks for the advice, any help on not getting ripped off on my gauge purchases?
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Personally, I would get EGT, boost, and wideband O2 if you intend on self-tuning. If not, you could probably swap the wideband for an oil pressure gauge.
    As far as brands, Defi, AEM, and Autometer are on the pricier side, but higher quality and accuracy than cheap brands like Prosport.
    I have had Defi Racer Series gauges in the past, and they've been great.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by Rambo View Post
    EGT is kinda meh...there is no real need for it unless you're tuning on a dyno and your tuner uses that. I have WB02, oil pressure and water temp in my clock pod and boost, oil temp and fuel pressure in my a-pillar pod.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Mt. Laurel, NJ
    I'm on the fence about oil pressure...I had one in my first STI, but think about it...if you have an issue and you've lost oil pressure, chances are your engine is effed already
    Don't knock Prosport...they are good quality gauges for a good price. They match the interiors of Subarus very nicely as well.
    Aug 2008
    Davey Jones Locker
    I disagree. If you lost oil pressure your gauge will show that before your oil light comes on (if it's a leak). You'll be able to shut it down.
    Registered User metaldahlberg's Avatar
    Sep 2010
    NH
    I have egt, wideband, boost, fuel pressure, and oil pressure. All from aem. Having both egt and wideband is probably overkill, but I am paranoid after having to rebuild my engine because of a failed walbro.
    Contributing unsolicited, worthless opinions since 9/10...
    The project I spend all my money on.... <---- Click it
    Jun 2011
    Norfolk, VA
    Thanks for all the help, I think I'm going to go with boost, wide-band O2 and oil pressure for the first gauges I get. Ill hit the next hurdle when I get to it. next question is, what should the oil pressure read on a healthy 04 STi?
    Mt. Laurel, NJ
    Quote Originally Posted by Drews View Post
    Maybe I had that backwards...I know I said it before...I think you're right. Its the stock oil light that's pointless when you're cars a brick and donezo. My bad.
    Texas, United States
    I have Prosport gauges and I would not call them "good quality" and I certainly wouldn't recommend them. Since I bought them in December 2010 I have had to send the oil pressure gauge and sender in twice to have it replaced (initially it was reading ~20psi low across the board, the second one worked fine for three months before it started not going below 20psi, over 20psi it read fine but when my pressure dropped below that it would just read 20.. not a good thing), and now my EGT gauge has stopped working (works for five minutes, then just pegs out and stays there).
    I have Prosport boost, oil pressure, and EGT in my A-pillar pod. I also have an AEM UEGO wideband O2 mounted in my cup holder, and an Aeromotive fuel pressure gauge mounted in the engine bay.
    Mt. Laurel, NJ
    Interesting...that is why I said "for the price" though. I guess for the hassle, or lack there of obviously, it may be best to just get something better.
    Did they replace for free at least?
    They've replaced them for "free", yes.. but for the cost of shipping a couple times I almost could have invested in better gauges in the first place and not had to deal with the hassle.
    They did look good, until they changed them, now my oil pressure gauge doesn't match the other two.
    I'd take EGT over fuel pressure or water temp, especially if you haven't messed with the FPR.
