08 wrx visor problem
Results 1 to 4 of 4
This is a discussion on 08 wrx visor problem within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Not really a "mod" but more of a fix. Hope I am in the right spot here 08 WRX The ...
    Jun 2011
    08 WRX
    The driver side visor suddenly stopped holding itself up and then eventually separated from the mounting arm.
    Are these replaceable as a whole or what options do i have? I have tried a few things to fix what I have. The plastic part on the inside of the mounting piece that goes inside the visor itself has the plastic broken off.
    I cant find a spot to order a new one....and if there is a place would it match the other one or would i just have to buy 2 and replace the other one which is good? its the light grey interior
    help greatly appreciated, its getting sunny out and cant see!!
    Any yes i did check ebay, only passenger side ones for an 08
    Jun 2011
    I guess a better question is - what year range has this same visor AND what other models share it? forester maybe?
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    If it's still under warranty, I would ask a dealer to fix it.
    If not, you can check out oem parts and order a replacement. https://www.subarugenuineparts.com/oe_parts_cat.html
    looks like it might be about $51 plus shipping.
    Registered User Warrior's Avatar
    Apr 2009
    North Georgia
    I've had the same problem and as you had mentioned, ordered OEM at about $50 plus shipping and installed myself. I think this may be a design flaw because the replacement is already starting to sag.
    Regards,
    MY08, WRX Sedan w/these mods: SPT CatBack, Perrin catted DP, Cobb AP with Perrin Stage 2 17.5psi 93 oct map, Perrin drop-in filter, Perrin 19mm adj rear swaybar and solid endlinks
