Results 1 to 5 of 5
This is a discussion on Dual coil sub connection Q within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey, I've got an Alpine SWR-1023 sub to put in my car, and I want to run it at 2 ...
    Mar 2011
    Ottawa, Ontario, Canada
    Hey,
    I've got an Alpine SWR-1023 sub to put in my car, and I want to run it at 2 ohms (the amp is Alpine MRP-M500). It is a 2 ohm + 2 ohm sub.....do I HAVE to connect on both sets of terminals, or can I connect to one without jumpering to the other? The manual indicates only 4 ohm or 1 ohm (not supported) configurations.
    Pardon my ignorance, it's my first dual coil sub. Thanks.
    2011 Spark Silver WRX 5-door. No mods....yet.
    2000 Navy Blue Camaro Z28. Some bolt-ons, stereo.
    Moderator Donkey's Avatar
    Da boonies
    You defeat the purpose of using a dual voice coil sub if your only going to use 1 coil. I would just run the voice coils in the 4 ohm configuration.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2011
    Yeah, that was my thought. My amp puts out 500W RMS in to 2 ohms and only 300W RMS in to 4 ohms, so there is a benefit to going 2 ohm. I'm working on exchanging the 1023D for a 1043D which I can run 2 ohm in parallel.
    Registered User patrick4588's Avatar
    May 2011
    South GA
    your amp isnt 1ohm stable?
    Mar 2011
    Manual shows no specs for 1 ohm operation. Only 4 and 2.
