Results 1 to 14 of 14
This is a discussion on Amp under passenger seat - where to ground? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; For those who have their amp(s) mounted under the front seat(s)..... I plan on putting mine under the front passenger ...
    Mar 2011
    Ottawa, Ontario, Canada
    I plan on putting mine under the front passenger seat as it will not get moved as much as the front, if at all. That should limit any wires rubbing or other potential damage. Anyway, just wondering where you grounded your amp.....on an existing chassis bolt, drilled in somewhere....etc?
    Thanks!
    2011 Spark Silver WRX 5-door. No mods....yet.
    2000 Navy Blue Camaro Z28. Some bolt-ons, stereo.
    Jul 2010
    Cincinnati
    I have not mounted an amp under the seat, but a perfect ground would be a seat rail bolt.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    They say you're not supposed to... but I agree. The seat bolts are stout and bolt right into the "frame" (if you can call it a frame)
    You are running power there anyway. If you don't want to use the seat bolts (and I can understand why) then just run a ground wire from the front and ground every component to the same point, somewhere in the dash.
    Supporting Member mjboudreaux77's Avatar
    Sep 2007
    Northern Vermont
    Depending on the power of the amp - this isn't a great idea. You want the absolute best ground you can get - the frame is ground so bolt right to that (seat rails are fine). You don't want IR drop on a GND wire from the amp.
    Also - my Kenwood mono amp never got hot, so I could see it being ok under a seat, but it was a class D sub amp. If you are powering anything besides a sub, you won't want a Class D (they are very efficient, but don't reproduce sound that great) - so yours might get hot if it has a high enough power output.
    If I don't die by Thursday, I'll be roarin Friday night - Jimmy Buffett
    Mar 2011
    It's an Alpine MRP-M500, class D mono amp, just powering a single sub. Neither of my Alpine amps in my other car get hot. I can touch them without sizzling after a good audio workout.
    Rule of thumb is GND no longer than 18", so it's gotta be somewhere close, and maybe my eyeballs are off, but it is more than 18" from the seat to the firewall.
    Sep 2007
    Northern Vermont
    Quote Originally Posted by GEARJAMR View Post
    Your MRP-M500 should be fine under the seat - they really just don't get hot. Why though? Is the sub going in the trunk? My Kenwood was powering a single 10inch in a sealed - there was plenty of room to mount the amp in the trunk without giving anything up. I ask because if the sub is in the trunk, now you are running audio speaker wires a decent distance to get to the speaker. You will probably need 12-14 gauge at smallest for that distance. I also found I needed to "tweak" my settings (LPF, gain, etc etc..) to get the sound just right. That might be a bit of a pain under a seat.
    Mar 2011
    yes, the sub is going in the hatch area. I have an Audio Integrations enclosure on order already. I want to keep the sub out of the hatch area for a couple reasons: 1. I often am throwing my hockey bag in the hatch, and having that sitting on the sub is not ideal, 2. I removed the cargo area cover so it is open and visible. The less someone can see, the better. Plus, under the seat, the amp is not going to get kicked (my kids legs aren't long enough) or jostled like it would in the hatch. And I've got lots of large gauge wire in the basement from running home stereo to different rooms.
    Sep 2007
    Northern Vermont
    I didn't realize you had the hatch.. now I get it.
    Good luck. Its going to sound awesome.
    Registered Whippersnapper mustangtx63's Avatar
    Mar 2005
    CS, TX
    I have my amp under the front passenger seat. I ran the ground under the carpet and to a bolt under the back seat. The bolt was hefty and connected to the sheet metal. Seems to be working great thus far, and this was even my first amp install EVER.
    ~ Retired Blobeye Syndicate #063 ~
    2011 Ford F-150 ECOBOOST 4x4
    May 2010
    Pittsburgh, PA
    Just a warning, in my van the seat bolts couldn't be used as (reliable) grounds. They were spot welded to the frame on the bottom, and as the car aged, it would lose conductivity. Just a warning.
    I actually cut a small U in the carpet to ground it in that car. Just be careful about drilling straight down - never know where things are hiding right under the car body (fuel tanks?).
    2011 STi Build Log
    Moderator Donkey's Avatar
    Da boonies
    Unfortunately unibody construction sucks for ground continuity. Grounding to the frame rail is a good idea as it usually is a pretty solid ground. You want the ground wire to be as short as possible to keep resistance low. I usually make it a habit to run a pretty large ground from the battery neg to the fire wall for in cabin electronics.
    2002 FORESTER S
    1998 FORESTER S
    Feb 2013
    I realize this is an old thread, but to anyone searching this topic, there is a factory ground point underneath the passenger seat.
    If you don't want to use this bolt, there is a hole right next to it that you can bolt for ground. There is paint there, so sanding a little around the hole may be advisable (although the factory ground is on paint, so it might be fine).
    Jul 2012
    South Florida
    I used the factory ground point for my Alpine PDX 9V under the passenger seat.
    2012 WRX - Ice Silver Metallic
    Audio mods:
    Pioneer AVH8400BT, ND-BC5 Backup Camera, GEX-P920XM
    Alpine PDX 9V Amp
    Morel Tempo 6 - 6.5" components
    CDT 6M Mid/bass 6.5"
    Stealth sub box with JL 10W3V3-2
