2011 WRX: auto up/down window switch - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on 2011 WRX: auto up/down window switch within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; What kind of person cant spare a few seconds to hold down the button? you people need to go back ...
    WRC Junkie Igor103's Avatar
    Nov 2010
    Chicago
    you people need to go back to crank thingy
    2011.WRX.PRM.GRB.WRB
    Stink-Eye Mob #103
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    The electronics are built into the switch and the motor, so you can't just move the switch to another door. There are aftermarket modules that would allow you to have this feature on other doors though.
    Registered User nyr8er's Avatar
    Feb 2011
    Cambridge, NY
    Quote Originally Posted by Officer Cartman View Post
    I'm pretty sure I saw a thread on NASIOC awhile back where someone did just that. I should have bookmarked it, as I'll probably end up doing it at some point if the parts aren't crazy expensive.
    one push down/up windows 2011 wrx? - NASIOC
    2011 WRX Base Hatch in Obsidian Black Pearl
    Stink-Eye Mob #027
    My Car
    - Mike
  6. #19
    Ayer, MA
    My guess at this point (as I haven't actually gone out and verified it) is that all of the "intelligence" for the driver side up-down is within the switch itself. The reason I say that is you can actually feel it click back after the window reaches it's upper/lower boundaries. If the relay was elsewhere then that "click" wouldn't be as obvious or felt at all. There are two (well, three) complications that I foresee with just snagging some switches and popping those in place of the other ones:
    1) Sensors in drivers side not present in others: it's possible that the switch is just a piece of a much more complicate solution that relies on glass pressure/position/etc. sensors. It's unlikely (it's a base-ish Subaru model) but possible.
    2) Common PCB for the entire pad: seems to be the case, in other words there is a single board onto which all 4/5 switches are mounted; swapping switches would be highly impractical, might required cutting board material, traces, etc - likely to deter much of the mocking around;
    3) Cost: assuming items 1 & 2 are non-issue/dealt with then it's a matter of how much $$$ it would be to source at least one (or 3 if you wanted to do all 4 windows) switch assemblies, it would have to be an 2011 MY Premium as 2010's are auto-down only. Junk yards are a possibility but cars are relatively new so they're uber expensive or not available at all, that leaves dealership and I would imagine that it's not cheap.
    Was just going to post up a similar message.
    I did realize that, but what I didn't realize was that it was pressure/click sensitive. I think all of the GM's that I've had in the past were time sensitive (hold it down for 2s or whatever)... There was never that 'click' threshold. Now that I know that, I like the functionality a lot. Its kind of silly though just being on the driver side. Only main use for it is drive throughs or the such.
    I don't know how simple or complicated Subaru made it. Could have some feedback from the window motor letting it know that it is done. May be as simple as splicing into the control to the drivers side window, putting a toggle switch on it so you can turn the functionality on/off, then splicing that into the other motor controls. I doubt it, however. Motors are kinda tricky little buggers, and I'd bet they have some complicated circuitry tied to them.
    "At dawn they sleep..."
  7. #20
    Ayer, MA
    The same type that enjoys luxuries of cruise control?
    Quote Originally Posted by Igor103 View Post
  8. #21
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    has anyone actually fished up a wiring diagram and had a good look at it? That will tell you without doubt how complicated the circuit is and if you can move the switches to other locations. I'm thinkin the auto function is turned off at window stop down or up simply by resistance/current draw. when you stop and electric motor its draw dramatically increases.. a switch designed to cut off at that point would work all by its lonesome without sensors.
    Think cheap people.. manufacturing a complicated system vs a simple one is the difference of millions in profit for the mfr.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  9. #22
    Registered User MagnumXL's Avatar
    May 2011
    I'd rather know why the stupid home-link mirror buttons don't light up. It's a PITA to find the right button at night without overly feeling or turning on the map light. I mean how much would it have cost Subaru to have lighted buttons for all the windows and the mirror? We're talking a couple of bucks at most. Given the price of the car, it's just downright ridiculous to half-ass these things, whether it's only one auto-button or one lighted switch. Geeze that smacks of 2nd rate crap. I've got to wonder what genius at Subaru decided only one button should be lit and only one should have auto-up/down on it. He should be fired.
    2011 WRX Limited DGM Sedan - SPT Catback - SPT STS + Kartboy Bushings - 3M Clear Bra
  10. #23
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by mangostick View Post
    I've used that method once in a pinch. It sorta worked. More commonly, I used PWM and a simple controller. Not out of neccessity, more so out of project requirements. If I can get a wiring diagram I can check it out. Any idea where to find one?
    I will dig through the service manual, it might shed a bit of light on the subject to at least see the hardware involved (thats visible)
    EDIT: http://forums.nasioc.com/forums/show....php?t=2127444 - people have done their homework already =). Scroll down a bit for the long post. Looks like aftermarket modules are the way to go.
    2011 STi Build Log
