Radar Detector - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 86
This is a discussion on Radar Detector within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; ahh ok that makes sense now thanks for clearing it up for me...
  1. #61
    Mar 2011
  3. #62
    Registered User djclue8713's Avatar
    Aug 2010
    Springfield, MA
    No problem!
  4. #63
    Mar 2011
    How are the Beltronics V8 or V6 in comparison to the Sti? I see a huge price difference but not much different in technology or looks or anything for that matter. If my price range was under 300, what would you guys suggest going with?
  6. #64
    Palmyra, NJ
    Quote Originally Posted by wrxtreme06 View Post
    same here. i've only been pulled over once in my 6 years of driving and i got away with a warning
    You have bewbs.
  7. #65
    Quote Originally Posted by justmike View Post
    If your price range were under $300 I'd consider any Beltronics below $250 but above $150 as that seems to be the sweet spot in bang::buck.
  8. #66
    May 2007
    orlando flawduh
    You have bewbs.
    Leave teh bewbage out of this!
    desiree
  9. #67
    Mar 2011
    is the Sti really that much better than the other Beltronics? I see here the Beltronics Vector 995 which looks very similar to the Sti but is $160 less than the Sti...
  10. #68
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by Fierceblues View Post
    Well....I'm pretty sure in California they are one in the same.
    A technology will be the same as another or differ from another regardless of where these two technologies are implemented. This means they are either the same or different in California just as they would be the same or different in Uganda or anywhere else.
    Are you sure your area uses laser and/or POP? I live in CA also and here they do not, meaning people are better off turning POP off etc.
    Yeah exactly. POP and instant-on are totally different. POP refers to a technology that shoots pulses rather than a steady beam, which is supposed to make it invisible to detectors. Instant-on isn't a technology, it's a means of operation. It has a trigger or other switch to operate it to allow the officer to turn it on instantly, as opposed to the old devices they used to use like the standard gray soda can looking one that was mounted on the rear driver's side window that were always on and took a little while to start up.
    Scott
  11. #69
    Registered User Nebuka's Avatar
    Feb 2011
    Quote Originally Posted by katzuu View Post
    I vouch for the Valentine 1. It is the only one with full 360 degree protection. Traditional radar detectors only detect what is oncoming. However, the v1 can give you signals for oncoming radar, to the side, and from the back. Don't mind the $500 cost.. think about it.. if it even saves you ONE ticket, it will already be worth it. Anything from there is pure gain. If you're going to get a radar detector, don't settle my friend!
    Here's a picture of how I mounted mine: (I have a 2011 wrx with auto-dimming mirror/compass). Used a blendmount and invisicord. The inviscord taps into the power of your mirror (1 minute install).
    I am looking to get the Autodim mirror for my 'stock' mirror now. Do you know if the autodim mirror comes up higher on the windshield or not? I feel the simple one is like halfway down the windshield, and If I add a radar detector it'll make it seem even worse... :/
  12. #70
    Registered User katzuu's Avatar
    Dec 2010
    Cupertino, CA
    Quote Originally Posted by Nebuka View Post
    The blendmount is practically invisible to me as a driver because it sits behind the rear-view mirror, holding onto the shaft. See my picture for reference. The only thing new in my line of sight is the v1, sitting directly below my mirror. It's good placement in my opinion because I can just look up and to the right a little bit to see what my radar detector is telling me. It's the same motion as looking into my rear-view mirror. It's secure and doesn't jostle at all.
    If you're having issues with your rear-view mirror being too low, you can always just move it upward.. The shaft is held on two pivot points: One connecting to the front windshield and one to adjust the angle of the mirror. Simply grab your mirror and lift it up gently against the front windshield pivot. That should help you out.
    Legal Issues - Radar Detector Laws - RadarBusters.com
    2011 WRX DGM Limited Hatch
    Stink-Eye Mob #408
    Cobb AP Stage 1, AEM CAI, SPT CBE, Tint, Red Tail Overlays, V1 hardwire, RA Mudflaps, STI STS, HT Auto Front Lip
  13. #71
    Registered User LetsWRCinmyWRX's Avatar
    Dec 2009
    Is there any way to install a detector in your grllle or something covertly, but have it signal you in the cabin? I mean, I know thats custom but is it possible to DIY or is that a professional job?
    Bugeye Mafia #155
    Friends don't let friends drive stock.
    Racing a neon is like fighting a girl: you can't brag about it if you win, and you don't want anyone to know if you lose.
    facebook
  14. #72
    There are remote radar detectors available that anyone can install.
  15. #73
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by LetsWRCinmyWRX View Post
    There are custom install detectors that are easy to install.Try the PASSPORT Qi45 - Escort Inc. or the PASSPORT 9500ci - Escort Inc.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  16. #74
    Apr 2007
    Valentine 1 has a kit to hide it. The K40 system is the standard one for having a hidden install though. Many people in the Porsche world use them.
    Scott
  17. #75
    RTM
    RTM is offline
    Jan 2010
    Nebuka. What length Inviscord did you get? I want to set up mine the same way in a 2010 wrx.
