Results 1 to 4 of 4
This is a discussion on Window Help Please within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My driver side window stopped working a few months ago. Swapped the switch out with a friends and still doesn't ...
    Registered User 2fastwagon's Avatar
    Nov 2009
    Window Help Please
    My driver side window stopped working a few months ago. Swapped the switch out with a friends and still doesn't work. Has to be the motor right?.....Also, are the motors in a sedan the same as a wagon?
    Perrin Short Ram Intake
    Invidia V3 Downpipe
    Invidia Uppipe
    Invidia N1 cat back
    Registered User Uh Oh's Avatar
    May 2010
    Charlotte, North Carolina, United States
    Switches hardly ever go bad. If the other windows work, it's the motor. If no windows work, you lost power to your door.
    -Holden
    Bugeye wagon - ERZ Uppipe - TurboXS Axleback - Swift Springs - JNA Lip
    Nov 2009
    Everything works except for diver window
    Invidia V3 Downpipe
    Invidia Uppipe
    Invidia N1 cat back
    Sep 2009
    check the bolts holding the motor inside your door. The same thing happened to me not too long ago and when i got to looking, one of the bolts that hold the motor in place came loose and the motor dropped, causing the wire connecting the power to it to come loose and the driver window would not budge. I bolted the motor back up and it worked like a charm. Hope this helps
