Dual stage boost control
Results 1 to 2 of 2
This is a discussion on Dual stage boost control within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi i recently go my new 07 subaru WRX. I has a boost gauge and a boost controller in the ...
    Dec 2010
    I has a boost gauge and a boost controller in the glove box.
    Everything was working fine on the yard but i forgot the process.
    What i would like help with is how to use the boost control knobs and use the boost. When i turn any knobs is any direction i can never get the the boost gauge to move or work. There is also a switch down by the cup holder i turn on.
    Is there something im missing? Am i meant to turn things on or off? in a certain order for the boost to work or show on the gauge?
    Help form anybody with knowledge on this would be great.
    Thanks in advance
            MainFrame's Avatar
    Austin, TX
    Ditch the dual stage controller, or, get a map pro tuned for each stage.
    In no form or fashion should you just be arbitrarily adjusting boost without adjusting timing and fuel accordingly.
    The gauge should have nothing to do with the controller. The boost gauge should take readings directly from the manifold. Sounds like things aren't hooked up right, and you could easily be causing damage to your engine.
