Results 1 to 12 of 12
This is a discussion on cant lock the doors with turbo timer ?? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi there i have a wrx 03 blubeye and just installed a hks type 0 turbo timer with a blitz ...
    Nov 2010
    Hi there i have a wrx 03 blubeye and just installed a hks type 0 turbo timer with a blitz harness but realised now i cant press the button to lock the doors untill the timer has counted down.
    I have looked on all the forums out there and read alot about a dark green with black stripe wire to cut that goes into the keyless entry module above the fuse box drivers side. I got home today and cant find any keyless module above the fuse box and also cant find the alarm module thats meant to be under the centre console or behind the glove box. My car has got the factory alarm with the keypad ?? Can anyone help me with this please where are the modules or cables so i can use the button on key to lock the door while turbo timer does its job any help will be great thanks
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    What do you mean that you can't press the button to lock the doors? They won't lock, they set off the alarm, or nothing happens?
    It's been awhile and I can't remembering the wiring, but when I had a TT in my bugeye my workaround for alarm/TT conflicts was:
    1 - park the car and keep it running
    2 - let any passengers out
    3 - lock all of the doors with the power doorlock button
    4 - manually unlock just the driver door by pressing the switch not the power-button
    5 - turn off the car...the TT will keep it running
    6 - get out and close the driver door
    7 - use the key to manually lock the driver door
    See if this works for you. Any other scenarios would set off my alarm.
    Steve // 2008 Lexus IS-F // 2011 WRX hatchback (SOLD)
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    easy fix....get rid of your turbo timer
    Its not doing your car any good
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Nov 2010
    When I press the button nothing happens. I can lock the car like that thanks.
    I seen threads saying if I cut the green with black stripe wire on the keyless entry module I would be able to lock doors with fob but I can't seem to find the module . Does anyone know where it could be other than above fuse box thanks again.
    Registered User 02bugg's Avatar
    Sep 2010
    Montgomery County, PA
    i just put an apexi tt in my bug eye a few months ago and im not able to lock the car using the fob either.
    what i have come to do is just lock my doors with the power lock switch inside the car, i am able to unlock it using the fob and thats all that really matters to me.
    i saw the rewireing things too but i dont know about you but im not down with cutting and splicing all of my wires under the dash.
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    The WRX is mad at you.
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Jul 2004
    Seattle, WA
    Quote Originally Posted by GarrettKoonsman View Post
    +1
    Please read this thread on turbo timers
    Mar 2010
    Utica, NY
    Thats strange, I can lock mine but can't arm the alarm until the car shuts off. I have an HKS Type 0 in my '02 WRX Wagon.
    Registered User Fleshwound's Avatar
    Nov 2010
    i have the same issue with my wrx with the turbo timer. seems to be a normal thing. i dont even use it anymore
    Texas, United States
    Why not just remove the turbo timer and sell it?
    Not only would that fix your problem, it would also put some cash in your pocket.
    Dec 2003
    Dallas, TX / Sterling, VA
    Alarm is going to go off anyways if the car is still running.
    Registered User fortunesk89's Avatar
    kenosha wi
    keyless module is above drivers interior fusebox held in by one nut
    2002 plat. silver wrx
