Need advice on previously gutted trunk...
Results 1 to 15 of 15
This is a discussion on Need advice on previously gutted trunk... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey guys so I have spent countless hours on here, NASOIC and a few other sites trying to figure out ...
    Registered User Smeee's Avatar
    Aug 2010
    Richmond, Virginia, United States
    Hey guys so I have spent countless hours on here, NASOIC and a few other sites trying to figure out what to do with this trunk that was previously gutted before i bought it. Even though the carfax says otherwise I would swear the car was rear ended and quite possibly the reason for nothing being in the trunk. Or its also possible that the leaks in the taillight gaskets where water poured in ruined all the trunk stuff and they simply tore it out. REGARDLESS, I am looking at this:
    So yesterday I got in a great debate with my dad over the proper response to the trunk. For me, I really don't care about this current setup, I have my tools, my disk golf disks, a spare tire, etc. and the road noise doesn't bother me too much. HOWEVER, the idea of it being totally quiet and looking better is cool too. Anywho, I have been debating on just buying eDead V3 and painting the trunk/doors/etc, but my dad argued that it would be cheaper and better looking to buy everything necessary to return it to stock. My issue is that I am struggling to find all the stuff I would need like the matt that would cover the metal, the board that would cover the spare, the carpet that would cover the board and then liners for the sides and the trunk anchors . While the latter sounds much more attractive and possibly more functional, I am just missing pieces of info and a grand idea of total cost. So for you wrx guru's I would love to know if yall can shed any light on this issue for me. Thanks a million in advance guys
    Apr 2007
    8000' up in Colorado
    You can only trust Carfax for what it DOES say. It will often leave things out. I had an accident in my old 911 that my insurance company paid a $30,000 claim on and it never showed up on Carfax.
    As for the trunk, I know from parting out my STi and selling all of the interior trunk pieces that you should expect to pay a few hundred for all of the parts. Contact a local junkyard to see if they have a wrecked WRX.
    Scott
    Aug 2010
    yup yup, i know b/c my old honda was rear ended a butt ton of times and it NEVER showed up on the carfax
    buuut yeah, i check the local junkyard inventories every few weeks or so, no dice. Only a couple old subbies anywhere near me
    I posted this up on my old accord forum and they are listing some ideas on actual parts and what not but i figured with you guys knowing these cars so well yall would have a bit more specific information
    Jul 2010
    Cincinnati
    Why not just call a dealer and order the parts? It may cost a little more but you may be surprised. On many occasions I've called junkyards about things and found the new parts to be cheaper than buying used
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    if your car got hit before you bought it, there is really no reason for all the trunk interior trim to be missing. you would be able to tell if they replaced the rear body panel or the floor by how the weld marks look. when a car is built at the factory, they use robots to do the spot welding on the unibody and most of the other welded panels, and they look super clean like little dimples all along the weld lines. if any of the welded panels were repalced, the spot welds would not be there anymore b/c a body shop cannot re-create those robotic welds.
    i have a feeling that this is not the case with your car. i think something flooded the trunk and they just ripped out all the funky interior trim and never replaced it.
    there are 4 parts that you need, the spare tire cover, rear carpet, and side trim panels. all new, this will probably cost you at least $400. however, you can do some of this yourself if you are at all technically inclined. for the spare tire cover, you can purchase a piece of thin particle board from home depot, and cut it to fit using either a jigsaw if you have one or a hand saw. the carpet that covers the rest of the trunk can also be purchased at home depot, its just thin all purpose carpet, which you can just use a heavy duty pair of scissors to cut.
    the only parts you may HAVE to buy are the side trim panels, which are made of a molded flexible plastic that you will not be able to create yourself.
    good luck, and it will look much better once you finish.
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
    Aug 2010
    Well I decided to go with the eDead b/c at the end of the day, I could really care less about the looks of the trunk, far more important to me was the functionality of it, which I get to keep with the eDead. I mean to snap a pic after all my stuff was put back in but i forgot, anyway, i thought it turned out great and it was definitely quieter afterward. What blew my mind was driving around with no backseats and an empty trunk, haaaa, geeeez the whine of the fuel pump, the sound of itty bitty gravel hitting the wheel wells, twas wild. Anywho, im glad she is put back together now and QUIET =D
    Im going to go back and put another layer on the doors and on the door cards.
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    How much did the coating cost you and where did you get it? I've been looking to do something like this in my 2010.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2010
    Quote Originally Posted by mangostick View Post
    How much did the coating cost you and where did you get it? I've been looking to do something like this in my 2010 but replace all the panels after its finished.
    It was 50bucks...well, 62 with shipping I think.
    Elemental Designs: Car Stereo, Home Speakers, Electronics
    I think when it warms up I am going to do a couple more coats, this cold weather es no bueno for this job. They recommend at least temps in the 50s, which it was when i started, buuuuuut i definitely had to use a heat gun in the end. Really the only road noise i am hearing now is coming from the front, buuuuut I have yet to figure out what to do about the front wheel wells...
    Oct 2009
    Nice.. link bookmarked! I can use that stuff for quite a few of the projects I've got kickin around. Thanks man!
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2010
    Aw for sure dude! What projects you talking about???
    I think come spring I am going to hook up a back up cam to my new x920bt and when I do I might pull the carpet and put this stuff down up front.
    May 2010
    Pittsburgh, PA
    It looks like a coating in this and a couple small MDF squares on large panels to help with resonance would really trump most sound deadening methods I've seen. I like the idea of just painting it on and being done with it. Good find.
    2011 STi Build Log
    Aug 2010
    ^^^Yeah I read about a lot of guys using eDead or dynamat squares first and then using this stuff to paint over it. Most of these guys are running huge stereos and claim monumental results.
    Oct 2009
    Quote Originally Posted by Smeee View Post
    First project is to coat the entire floor area of my wrx in it... likely anywhere else I can easily pop the panels off to get at sheet metal I was planning on using dynamat but if this stuff works just as well I'd rather paint it on let dry and be done with it.
    I'm also building a pair of subs for my living room, this will work nicely to coat the inside of the enclosures before the poly fill goes in. Even though they're small with out any really long panels (sealed enclosure, plate amp and 8" woofer in each) coating the inside to bring resonance down is very important. I want to feel the effects without hearing buzzing boxes
    I'm sure I'll be able to find other uses too. How long did it take to dry?
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2010
    WORD. yeah dude i was amazed at how little of this stuff I used. I had read that a gallon was enough to do roughly the whole trunk and then the front door cards, buuuut I seriously did all that, the little space where the back seats are and still have roughly a half gallon left. NUTSO!
    Dried pretty quick and that was with temps in the 50's. BUUUUUUT, they recommend the temps be AT LEAST in the 50's, I won't do this again until spring time b/c of that. There were a couple places in the trunk that didn't dry fully and the next day when I put a towel on it to 'dry it off' the stuff came right off. It just never set. Anywho, i put on another couple coats, used the heat gun and she is golden. The tutorial video they have on their site says that there in Arizona with temps in the 90's its ready for another coat in 5-15min and dried completely in 30-60min.
    May 2010
    Pittsburgh, PA
    I would still look into some MDF or whatever it is squares. I found a site that sells 8"x4" or so rectangles of the stuff. Its the main component in dynamat. You use them just to add some mass to the larger panels in the center to prevent resonance. This stuff I'm sure is more of a sound blocker, which you should use in supplement to 'resonance damping'. No need to cover panels in MDF, just stick a patch of it in the middle of the panel. I haven't tried out this new stuff, just some food for thought.
    2011 STi Build Log
