Results 1 to 5 of 5
This is a discussion on Aux Input for 2011 WRX is too quite, why? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I use a Sansa Fuze mp3 player and am trying to use the Aux input in the console. It works, ...
    Registered User Chader's Avatar
    Jan 2010
    Billings, MT
    Question Aux Input for 2011 WRX is too quite, why?
    I use a Sansa Fuze mp3 player and am trying to use the Aux input in the console. It works, but with one annoying bug.
    I have to crank the head unit to the max volume of 40 and crank my Fuze up very loud to hear anything from the stereo. Then if I try to increase my volume with the Fuze even more, the stereo "skips" during playback and cuts out like it is being overloaded or something.
    It almost seems like I need a small headphone amp or something to boost the signal from my Fuze so the signal is stronger and I don't have to max the stereo just to hear.
    I suppose it could be my 1/8" cable because it is just a cheap 3 footer.
    Is anyone else having similar experiences?
    This sounds like an impedance mismatch. If the aux input on the car's head unit is expecting a line level input, that is typically over 200Ω and can reach to several 1000Ω, whereas typical headphone output -- I'm not familiar with your device but am thinking you are using the headphone output -- can be 100Ω or less. The voltage output may be insufficient also; I know that some Apple devices are around 2V whereas some domestic audio devices reach twice that on their outputs, for example.
    If you can use a proper line out from your source device, try that and not headphone output.
    ED: Since players do this because they are relying on batteries, I wonder if powering the player would improve your situation. I doubt it, but it'd be clever if the maker made this provision.
    Jan 2010
    Billings, MT
    I'll bet you are right. Yes, I am using a headphone output since it is the only one on the player. I didn't even that about impedance.
    Now that I think about it, I have the same problem when I run the player through my home stereo too. I have to really crank the volume on the stereo and player to get any significant volume. It must be from the reduced output intended for headphones.
    Alternatively, I tried using the power/audio cable running from the player through the USB port in the console. Unfortunately, the player switches to a "connection" mode that is for data transfer only. It acts like when I have it connected to my PC to load songs. So I can't get audio output from it to the stereo.
    Looks like I need to find a DC powered mini-amp or something to increase my output prior to the aux input.
    Check again online with other users of that player, maybe it has a setting via USB or something else. You can't be the first person with this problem.
    Jan 2010
    Billings, MT
    I found some similar threads in the Sansa Fuze forums. One possible solution seems to be this "Line Out" dock that converts the data port to a 1/8" stereo plug for better signal output.
    http://www.amazon.com/FiiO-L6-Line-C...ef=pd_sxp_f_pt
    I plan to order since the price is reasonable. Thanks for the suggestions.
