There should be two 12mm bolts near the footwell to remove the bottom rear seat cushion. There will then be four 12mm bolts to remove the top rear seat cushion.
The rear brake light requires you to go in through the trunk, if I recall correctly (been awhile since I removed one).
LinkBack URL
About LinkBacks
