Results 1 to 15 of 22
This is a discussion on a question about 52mm gauges within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; a set of boost, fuel pressure, oil pressure defi gauges are on the way. they are 52mm looking to get ...
    Registered User irvin787878's Avatar
    Jun 2009
    Milesburg / Near State College PA
    a set of boost, fuel pressure, oil pressure defi gauges are on the way. they are 52mm looking to get a dash pod for them i am thinking about getting the auto meter one. its alittle cheaper than the defi one. my question is does anyone have it what do they think about it. also 52mm is the same as 2 1/16 correct. thanks in advanced.
    HAWK-EYE ALLIANCE #7878
    2007 WRX TR
    My work in progress. http://www.clubwrx.net/forums/off-to...ld-thread.html
    Dec 2003
    Dallas, TX / Sterling, VA
    2 1/16" = 52.39mm
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    I have the Autometer dash pod.
    Its good..... and it's good quality.
    However, the lack of a "hood" over the top of your gauges will cause a significant reflection in the center of your windshield at night.
    I've gotten used to it over the years... but it was VERY distracting at first.
    If someone were to trade me a hooded dash pod for my Autometer non-hooded dash pod..... I would accept.
    EDIT:
    This is a terrible, blurry picture of the interior of my car.... but if you look at the very top of the picture, you can see the "reflection" I'm talking about.
    Again.... the pod is smaller, and more discreet than the massive hooded pods.... but you have to deal with the reflection at night.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
    Get a "hooded" clock pod. As ninefourteener pointed out, the glare on the windshield sucks at night. Also, the hood helps keep the sun reflection on the gauges down, making them easier to see during the day.
    I have an ATI pod in my car, and sitting in the driver seat, I see my hood scoop over the pod. It's not as obtrusive as you may think.
    Jun 2009
    Quote Originally Posted by brfatal View Post
    2 1/16" = 52.39mm
    ok thanks
    2007 WRX TR
    Jun 2009
    Quote Originally Posted by ninefourteener View Post
    thanks. i will get one with a hood. autometer one has the gauges angled. some of the other ones are not angled is there a big difference when you look at them.
    2007 WRX TR
    Quote Originally Posted by irvin787878
    Here's the view of mine from the drivers seat:
    I have no visibility issues unless the sun is coming through my back window.
    Jun 2009
    awsome thanks. what gauges are they. they are a perfect match.
    i got them from ebay used the only thing is they dont have instructions. bummer
    i have an 07 wrx tr
    will i need adaptors for the sensors to screw in.
    i seen a post on where to put the oil sensor in but i cant seem to find it. any help on that would be great. also where does the fuel pressure on screw in. i havent searched for the boost pressure on yet but any help there would be great also. thanks.
    2007 WRX TR
    Jun 2009
    i found a post u made to a person on the install of a boost gauge and pics but its an 05 would that work for my 07 also.
    2007 WRX TR
    Defi Red Racers
    You have two options:
    1) Galley plug. I tapped my oil temp gauge into the galley plug under the TMIC. It's on the engine block near the turbo. I believe it's an 8mm hex socket.
    2) Sandwich adapter. This goes between the block and the oil filter.
    Looks like I found ninefourteener's install pic
    Tap the vacuum line coming off the BPV. You can see his T in the left part of that picture.
    Jun 2009
    Defi Red Racers
    no adapter needed for the galley plug and my sensor right.
    is the brass looking t fitting in the pic on the car from factory or do i need to find that.
    got it on the boost gauge.
    thanks for your help i appreciate it.
    2007 WRX TR
    https://www.subarugenuineparts.com/p...roducts_id=961
    I got mine from my local dealership.
    http://prosportgauges.com/fuel-press...g-adaptor.aspx
    Jun 2009
    can i use regular teflon tape for the threads of the sensors or should i get something else that may be better? sorry for all the questions. thanks for all ur help and giving me these links above. i might take the part number to the local dealership before getting it online also. thanks again
    2007 WRX TR
    May 2007
    behind the wheel
    I don't recall using teflon tape on mine, ever. Reasons: threads are tapered and shouldn't need it. #2: the sensors need grounding, and do so through the threads. Teflon tape can hinder this.
    Sent from my HERO200 using Tapatalk
    Rogan o_0
    '01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
    Jun 2009
    ok thanks alot
    2007 WRX TR
