Cluster needles not bright enough after conversion
Results 1 to 11 of 11
This is a discussion on Cluster needles not bright enough after conversion within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Few months ago I did a blue led conversion where I simply swapped out the cluster bulbs with LED twist ...
    Registered User as13070's Avatar
    May 2010
    Mass
    Few months ago I did a blue led conversion where I simply swapped out the cluster bulbs with LED twist lock bulbs. The gauges looks great but the needles are very dim and hard to see at night. How do i make the needles brighter?
    2004 Java Black Pearl WRX Sedan
    New England Flat 4
    My Modifications
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    did you adjust the lamp adjustment on your left side of the steering wheel (same "stick" as the turn signal)
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    May 2010
    Mass
    Yep its on the brightest setting
    New England Flat 4
    My Modifications
    Nov 2006
    Denver Metro Area
    Sorry... Had to ask!
    Were the LEDs the same wattage?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    May 2010
    Mass
    Oops. Not sure. I just found the replacement LEDs for the bulbs
    New England Flat 4
    My Modifications
    May 2010
    Mass
    I just looked up the LEDs. Heres a page with all the info for them
    http://www.superbrightleds.com/cgi-b...s%2F74_t15.htm
    I used mostly the T1.5-B and a few T1.5-BHP
    New England Flat 4
    My Modifications
    Registered User Graham46's Avatar
    Mar 2010
    Harford County, MD
    Can you show us a picture? I bet it looks pretty sweet, dim or not
    2006 WRB WRX Sedan @ Stage 2
    www.grahamsnodgrass.com
    May 2010
    Mass
    New England Flat 4
    My Modifications
    Registered User subarusugi's Avatar
    Mar 2011
    Vancouver Island BC Canada
    Quote Originally Posted by as13070 View Post
    Did you ever find a fix for this?
    Sep 2008
    I did. After trying multiple LED's, I ended up going back to the standard incandescent lights and got the needles back to the correct brightness. The problem that I encountered with the LED's was that I only purchased about 8 different types to test, and none of them fired in exactly the correct direction to illuminate the needles properly.
    Mar 2011
    Quote Originally Posted by KryptoNyte View Post
    I figured it was going to come down to that, thanks info!
