Best place to mount radar detector? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Best place to mount radar detector? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; From what I've gathered, radar detectors are very nice, as you can detect the signal from much farther away than ...
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    From what I've gathered, radar detectors are very nice, as you can detect the signal from much farther away than it takes to slow down...
    Laser detectors are useless - by the time you detect the laser, the cop has already caught you.
    Laser jammers - which are legal, since they are regulated by the FDA, not the FCC like radar - are super-effective against laser threats.
    EDIT: man, I'm tired. it took me that whole post to realize nothing had to do with OP . Anyway, mount it high - you'll be worse at detecting laser but significantly better at detecting radar, which is really the only important thing.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Quote Originally Posted by silverbullet207
    So to everyone out there with a V1, which setting do you use:
    - The one that looks like an "A"
    - The one that looks like a lower case "L"
    - The one that looks like an upper case "L"
    Advanced Logic (full "L")
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
    Registered User silverbullet207's Avatar
    Dec 2009
    Cincinnati
    Ok that is what i have been using. I can pick up everything except laser, it doesnt seem to work when i am thinking it should
    ** Hawk-Eye Alliance #513 **
    '06 WRX Stage 2
  5. #19
    AL will still pick up that band, but I have only seen it a few times
  6. #20
    Registered User MULEZSTI's Avatar
    Jul 2006
    Central GA
    Full L for me too. And it picks up laser. Now its sets off the laser signal for red light cameras and those luxury cars that have the smart cruise control that radar or laser guided. I hate being a head of someone who has that on.
  7. #21
    Registered User wo^tron's Avatar
    Jun 2010
    Naples, FL
    Quote Originally Posted by silverbullet207 View Post
    I stick to super logic "big L" in cities where radar is polluted and then little l (logic) and sometimes "A" all bogies when Im on the highway.
    I just have a theory that little l and A process the alert faster than super logic, and since your going faster on the interstate you need to slow down quicker if you see a cop.
    Its most likely just superstition though
    Put aside the everyday world and come with us
    Into the realm of imagination
    The middle ground between light and shadow
  8. #22
    Sep 2008
    Quote Originally Posted by queenstown3 View Post
    Hey, i recently just bough a Escort x50 8500 Radar detector. I have mounted to the middle of the dashboard just above the clock with double sided tape in my 04 wrx sti. I was thinking that maybe the hood scoop would intefare it from detecting properly? Is this the best place to mount it?
    the higher the better, think about line of sight
  9. #23
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by amoujaffar View Post
    Not when it comes to laser. Usually they will be shooting at your front license plate, and the spread on the beam might only be a foot or two in diameter. So lower is better for laser, higher better for radar.
  10. #24
    Quote Originally Posted by MainFrame
    This.
    Since laser triggers aren't as useful as radar, I would suggest mounting it as high as possible.
  11. #25
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    best place to mount it is on the shelf of the store that sells them. Drive smart and within your means, also the speed limit is your friend
    Lead Wrench @ WTF Tuning, LLC
  12. #26
    Quote Originally Posted by T0rque
    There's more to using a detector than simply installing it and speeding like an idiot. It's another tool in the arsenal. When used properly, they're very effective.
  13. #27
            MainFrame's Avatar
    Austin, TX
    Both of the above have valid points.. in reality you should not speed at all. Although, without a detector I would never have felt comfortable making the trip from Austin to Denton in 1hr and 40min.. I know for a fact that I can break the law more comfortably with the detector than without. That doesn't mean that breaking the speed limit is okay, or that the detector will keep me from getting caught... it's a tool, to be used at your discretion.
  14. #28
    Jul 2010
    Have my 8500 suction cupped about 5 inches above the clock in the middle so it can read behind me between the seats. And per the 8500 manual and also research ive done it says mounting high is actually BAD...from all the reading ive done it says mount it as low as possible while not having it blocked by windshield wipers or a scoop. Am I totally off base or crazy or what? - Mount Detector Properly - RadarBusters.com In bold says "Don't mount it high" and says "Mount it Low" so im not sure what to go with
    here is just one quote from the site "By mounting it this way, making sure that the windshield wipers are not blocking the front, you will draw the least amount of attention and obtain the best laser and radar detection."
  15. #29
    Quote Originally Posted by trueX
    Higher mount: better for radar
    Lower mount: better for laser
    What do LEO in your area use most?
  16. #30
    Jul 2010
    In my area I have never had anything but K or Ka go off, so no Laser so far but still it says "you will draw the least amount of attention AND obtain the best laser and radar detection." So I am still torn on mounting the detector high even though my area is almost all K or Ka band. I think ill just split the diff and move the detector up 2 inches or so and hope for the best
