Results 1 to 7 of 7
This is a discussion on 2002 wrx stock oil pressure within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i want to get a oil pressure gauge for my 2002 (plan for the car are to get 400-600 whp) ...
    Registered User BrandonPaquette's Avatar
    Dec 2009
    Sudbury, Canada
    i want to get a oil pressure gauge for my 2002 (plan for the car are to get 400-600 whp) how much oil pressure do you think the gauge with need to read.
    Brandon Paquette
    The manufacturer considers 1 kg/cm^2 or 98 kPa or 14 PSI normal oil pressure at 800 rpm.
    At 5000 rpm normal pressure is 3.0 kg/cm^2 or 294 kPa or 43 PSI.
    These numbers are MINIMUM acceptable pressure; readings can and will be higher.
    Definitely expect higher pressures at cold startup.
    I don't use a gauge but have seen 2.0L motors exceed 100 PSI on startup, and exceed 75 PSI during normal use.
    Dec 2009
    Sudbury, Canada
    oo i see ok i want to get a oil pressure gauge electronic one but it only get up to 100 pis. is it still ok if i install it or will it hurt the gauge.
    http://www.autometer.com/cat_gaugede...id=3099&sid=11
    Brandon Paquette
    Texas, United States
    My gauge reads up to 100psi and it is maxed for about 10 minutes when I first start the car. When I tested it with a manual gauge it was 125-130psi cold.. of course that's not stock, but I don't think it's far off from what a stock engine would run.
    Dec 2009
    Sudbury, Canada
    Do you think the gauge with get any damage or the sender ?
    Brandon Paquette
    Since these gauges are not cheap and neither are motors, I'd ask the gauge manufacturer.
    I think the Autometer gauge would be fine, but it wouldn't hurt to call and ask them.
