Windshield washer now intercooler sprayer
Results 1 to 15 of 15
This is a discussion on Windshield washer now intercooler sprayer within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; So I went the cheap/lazy route and bought some mist nozzles and just used my existing windshield washer pump for ...
    Mar 2009
    So I went the cheap/lazy route and bought some mist nozzles and just used my existing windshield washer pump for an intercooler spray.
    Works pretty well... except the windshield wipers taking a couple swipes when I hit the button :facepalm: Which I didn't even think about.
    So does anyone have a clue how to disable that? I know I will eventually do it right and buy another motor and switch. But for right now in this Houston heat, it would be nice to get it working without the extra hassle.
    PS: I used Aeromist nozzles and they work great.
    Oct 2008
    ACT
    Get a wagon washer bottle - front motor for your windshield, rear motor for the I/C.
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Stop being a cheap ass.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Drews View Post
    +1
    Quote Originally Posted by bobbyjimmy View Post
    This is the right way to do it if you want to be cheap.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User Pactin's Avatar
    Nov 2007
    California
    Tried this method on my friend's 09 Sedan. Even took apart the interior's wiper lever assembly in hopes to disable the wiper motor when spraying.
    Best way as mentioned before is to create a separate reservoir/ pump.
    --Justin
    Hawk-Eye Alliance #128
    Mar 2009
    I have a hatchback. So I just need to wire the rear washer motor to a new switch. That should be easy. Thanks.
    Mar 2009
    So I'm ready to wire my new switch to the rear washer pump (Now IC sprayer pump). Does anyone have how to's on accessing the fuse box wiring?
    My thoughts are to tap the negative side of the washer pump fuse. Wire to my on off rocker switch. Then find the positive wire to the washer pump. Cut the positive and splice my switch.
    Battery---Fusebox---Switch---Motor---Ground
    Someone asked me if the motor was on a relay. Does anyone know for sure?
    Nov 2009
    No need to mess with any wiring. Just use the OEM switch that you use to spray the rear window. It will also turn your wiper on but you can always disconnect it if you don't like it turning on.
    Mar 2009
    Naw, I have an on off switch so I don't have to hold the button down, and I do mind having the wiper flapping around for no reason, and I don't want to disconnect it all together because it is useful on rainy days.
    Anyway, my first thought was to tap the main battery cable and fuse it somehow. Run through the switch in the cabin and back out to the motor, but if I can use the existing fuse circuit, I could bypass a lot of extra cable.
    Aug 2008
    Davey Jones Locker
    Check your owners manual. I believe there is already a fuse for the rear resevoir on the interior fuse box.
    May 2010
    Pittsburgh, PA
    Wouldn't you want that flipping on and off at least?
    I don't know how fast that stuff evaporates, but if it doesn't evaporate almost immediately, you probably would not want to constantly spray it. It might puddle on fast enough it wouldn't evaporate (required to take heat with it don't forget) and just drip off.
    I might be taking a shot at the dark, but I would guess you'd want it on some type of duty cycle. Maybe flicking on for a few seconds, then off for 10 or so depending on how fast it evaporates. You would still run it on the switch, but the switch wouldn't keep it on the entire time if you know what I mean. You could probably use a relay and a bit of creativity to do this. Let me know if you want some ideas.
    EDIT: Okay, so I looked around and the sprayers are such a fine mist it shouldn't ever 'puddle' up or drip. Bad call on my part. I am surprised stock windshield washer pumps would have enough torque to support the head pressure needed to use such a fine mist nozzle.
    2011 STi Build Log
    Mar 2009
    The way I see using it, is a 10 second shot at low speed. The nozzles are a very fine mist and I wouldn't leave it running. My idea was to cool it off in between auto-x runs or after being stuck in traffic in Houston's heat. Its not something I would use every day.
    I'm more of the opinion that if you get one of these boost controlled duty cycles, you're too late to cool off the intake charge. Water is pretty much only going to get the IC back to cold start temperature or closer to it.
    I am interested in what they can do with these CO2 intercooler sprayers. That seems like a good inovation to CAI if the intercooler can handle the heat cycles.
    Edit: I have it hooked up to my front windshield washer pump now. The nozzles are designed for low pressure systems and work pretty well, except for some dripping after a spray, so I am thinking of putting a filter or check valve in the line to fix that.
    May 2010
    Pittsburgh, PA
    Well, not to sure about the mechanics of that. I was just shooting some ideas out there.
    I understand what you mean about the timing of the spray. It makes sense. Switch is nice and easy too. I was more concerned with soaking the IC to the point of dripping for no reason.
    Don't know how the check valve or filter would help out the dripping ordeal much. I think it's just a pressure vent sort of deal - once the pressure of the pump stops it drips until it reaches normal pressure. Maybe a check valve of sorts that is only open at a certain PSI?
    2011 STi Build Log
    Mar 2009
    If you put a filter close to the nozzle, it will prevent gravity leakage. But now that you mention it, it's not dripping that bad. Just a few drops, so its probably is the pressure like you said.
    I'm just trying to think of how to get the wiring right. Hopefully all I have to do is run power from the fuse box to the motor, but if there is a relay I'm not sure that will work.
    I dont think there is, because the wiper motor and the washer motor has seperate fuses.
    May 2010
    Pittsburgh, PA
    I'm not sure what type of current those pumps need. Worst case scenario, take a lead from the battery. I doubt it'd have to be large at least. Somebody might be able to pitch in here.
    Relay wise, just put a relay in between a constant power and the pump, and then run the control part of it up to the switch or button you pick.
    How is the normal pump powered?
    My guess with the drips... The reason I assume its a pressure vent. The nozzles use a pressure to force water into the fine misters obviously. When that pressure gets under a certain threshold, the water would rather stay on the inside of the holes with the rest of the water in the pipe (vanderwaal forces/surface tension sorta thing). Even without the mid pressure, I would guess there is some form of capillary action going on there. Small hole... water... strangest natural force in my opinion. The water will seep through the hole like coffee going down the side of your cup onto paper. As it seeps out the hole, it collects and drips out due to surface tension.
    It doesn't drip after a while though? Maybe just a simple pressure release somewhere in the system might help, but if it isn't bad, I wouldn't worry about it at all.
    2011 STi Build Log
