Extra plug inside center console???
Results 1 to 4 of 4
This is a discussion on Extra plug inside center console??? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was messing around and had part of my center console apart. Underneath the piece that holds the rear view ...
    Registered User CATALYST's Avatar
    May 2010
    I was messing around and had part of my center console apart. Underneath the piece that holds the rear view mirror switches/seat heaters I found an extra plug just sitting there. Its got a while connector, probably 6 to 8 pins. Anyone know what this is for??? There is a blank switch stop just forward of my window control and I noticed the cable reaches to that point. Thanks
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    someone may know better than I, but perhaps it's wiring for the dccd? that, if you had an sti, would have its controls in the center console, and would need some wiring run to the diff...
    ...dunno why they'd put the wiring in on a wrx, though...
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    May 2010
    Pittsburgh, PA
    Get a half decent picture of it, might help out. Even a crappy cell picture would do the trick.
    2011 STi Build Log
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    If you can't get a picture of it in a post, there's only so many options available, mirror controls, rear windshield defrost, intercooler spray, reverse foglamps, DCCD, 6 disc/10 disc changer control, amplified subwoofer, reverse sensor wire (one wire, and so you can rule that out). Otherwise, if I am missing one, clue me in, I'd guess it is the changer control from the stock radio/CD controller deck if you don't have one.
    +1 on a picture, we'll know immediately what it is if you can post one up.
