Possible blown speakers/amp help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on Possible blown speakers/amp help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally Posted by LPPTundWRX Sounds like the frequency you hear is probably your alternator which means you could of popped ...
    Registered User MMC_555's Avatar
    Oct 2001
    MSP
    Quote Originally Posted by LPPTundWRX View Post
    Sounds like the frequency you hear is probably your alternator which means you could of popped the noise reduction in either the amp or the deck.
    +1 its either something along these lines or you have a grounding problem. Check and make sure everything is well grounded...
    Mar 2010
    Staten Island
    both amps are grounded on a bolt underneath the trunk liner..seems to be good as i haven't had a problem untill last night
    Oct 2001
    MSP
    hmmm... not sure then, but my money would be alternator noise, as it seems that the pitch of the whine/buzz goes up with engine RPMs....
  6. #19
    Mar 2010
    Staten Island
    yeah i'm reading about alternator whine and that seems to fit the bill...but i have no idea why it started last night. maybe i shorted out something on my amp?
  7. #20
    Mar 2010
    Staten Island
    actually now that i think about it..there's been a slight whine at different RPM ever since I got my 2nd amp put in. but it was very slight and only noticeable when the volume was low so i didn't really think anything of it. but now it's 100x worse
  8. #21
    Oct 2001
    MSP
    I'd still double and triple check the grounding....
  9. #22
    May 2010
    Pittsburgh, PA
    Is it a pioneer head unit?
    Pioneer and a few others use a pico fuse on the head unit side of the RCA grounds... Sounds strange and unimportant, but if fooling with power while the RCAs are plugged in, it blows, easily.
    Instead of fixing the fuse, wrap a bare wire around the outside (ground) of the female RCA connectors on the back of the head unit, and screw it into the head unit chasis or ground them somehow.
    I'd put $10 on that helping if they were fine to begin with.
    EDIT: Snagged a good picture of google to help explain...
    2011 STi Build Log
