Results 1 to 9 of 9
This is a discussion on door panel rattle within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; hey, so i just installed a new set of front door speakers in my 04 wrx. i had to remove ...
    Registered User 2004wrxkid's Avatar
    May 2010
    door panel rattle
    hey,
    so i just installed a new set of front door speakers in my 04 wrx. i had to remove the hole door panel on both side of the car in order to do it. now when my speakers are turned up there is an abnoxious rattle on the passengers side door. Any home made device, blanket, buble wrap, anything to stop this.???
    or maybe my door panel isnt put back on correctly.
    help me yoooo
    Registered User Strobe Media's Avatar
    Apr 2010
    Harrisburg, PA/Conway, SC
    dynomat my friend, dynomat
    May 2010
    yesir, i just dont have a spare 170$ lying around. i just made my liner out of a towel. cut that shz up. works well
    Apr 2010
    eBay, much cheaper than best buy
    May 2010
    werd? never got the chance to figure ebay out lol
    Registered User erksplee's Avatar
    Sep 2009
    PA
    I just did my speakers too. I guess I got lucky, I didn't get a rattle after doing mine. It's possible that your speakers themselves are rattling with the hole that they go in. I have a layer of cardboard between the metal and the speakers. Rattling is generally always a loose bolt or at the source of a mod.
    May 2010
    yea, i did something similar to that.
    May 2010
    Pittsburgh, PA
    They make off brand dyno mats. They aren't the best. Some are harder to stick, some need layered etc. If its only in your passenger side, though, I'd lean towards the panel not being on right.
    I dont' have a wrx, how is the door panel put on? I have only worked with GMC type vehicles. The push pins GMC uses on some of their vehicles is not my favorite choice; they always dont' go in quite right and rattle.
    EDIT: After browsing over this again, double sided tape (the foamish kind) is great for reducing rattles. It isn't perfect, but it does the job sometimes.
    Registered User ZJbrandon's Avatar
    Apr 2010
    if you are still getting rattles, take the panel off and look at the lower-rearward section. On my 2010 there is a plastic box structure (I'm guessing for strength/reinforcement), perfectly positioned to rattle against the door itself on one side, and the door panel on the other. I used some adhesive backed foam and rubber strategically placed - killed the rattles.
