Just look in your fuse box, there should be a labeled diagram telling which is which. And when you find the blown one it will say on the fuse itself how many amps it's for.
If you accidentally grounded the hot wire in the process of wiring things up that would blow the fuse almost instantly. Make sure your are wiring things correctly, a DMM is your friend.![]()
LinkBack URL
About LinkBacks
