Quick headlight wiring question
Results 1 to 6 of 6
This is a discussion on Quick headlight wiring question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; On the stock headlight plug (9007 2003 wrx). There are three wires. Blue/White, Red, and Yellow/Red. I need to know ...
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    On the stock headlight plug (9007 2003 wrx). There are three wires. Blue/White, Red, and Yellow/Red. I need to know which of these is the high beam control. Im assuming red is 12v power, and my guess is yellow/red is ground?? Im not really sure, either way all i need to know is which one is the 12v high beam control. If for whatever reason none of these are a 12v high beam i need to know where to find that wire and what color it is. Thanks
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Apr 2009
    CO
    anyone? If not guess i'll be taking a test light out there in the morning and figuring it out
    Mods
    Pics
    See the diagramme attached. LW is the code for blue/white. Notice that the two filaments share a common positive. This is a switched negative system -- the ground is switched, not the power. Notice that it is LW that goes to the fuse box, not R or YR. These two both end up to earth (they ground).
    What is it that you are trying to do? Someone may have already figured out a circuit for your particular application.
    - Al Stewart
  5. #4
    Apr 2009
    CO
    im wiring my garage door opener to open with a flash of my high beams. Found a DIY and all i need is a 12v activiated by the high beam and a ground. Ground is easy, i just need to know where to find a wire that will only supply 12v when the brights are on
    Mods
    Pics
  6. #5
    Oct 2005
    Late Devonian
    Maybe the one that goes to the high beam indicator in the cluster?
  7. #6
    Feb 2010
    hey mate - im an auto electrician.
    on any type of headlight wiring there is always a power feed for that circuit e..g. high beam power
    if there is negative switching at the headlights u can:
    1 - find power at the cluster or the headlight switch
    2- wire this up as if u were wiring in spotlights which need the high beam trigger.
    now three wire bulbs are usually high and low beam
    all u do is join a twin core wire on the COMMON side of the headlight- and the other wire on the opposite end
    the little diagram below shows three terminals and the stars show which ones to join to...
    now one of those wires have to be cut and put across the coil of a stardard relay - terminals 85 -86
    then join the end of that twin core wire together
    85 86
    _________l l___________________
    _________________________________/* join these two
    the terminal 30 on the relay is put through a fuse to battery positive
    the terminal 87 on the relay goes out as the HIGH BEAM power to your unit
    see how u go. let ur imagination run wild! just dont let the smoke out!!
