Results 1 to 14 of 14
This is a discussion on gauge help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; prosport oil pressure gauge(new) works fine at idle, but as soon as I step on the gas the gauge pegs ...
    Registered User Dos-fivewagon's Avatar
    Dec 2009
    portland
    gauge help
    prosport oil pressure gauge(new) works fine at idle, but as soon as I step on the gas the gauge pegs max and stays there until I hit a light and the cars idling again. Anybody have any suggestions on how I can fix this? It would be cool to have a functioning gauge while driving.
    One industrial accident away from financial freedom!
    Blobeye Syndicate #215
    Buy a Defi/Greddy/Omori gauge
    Registered User Felginator's Avatar
    Jun 2009
    Parsippany, NJ
    Contact Prosport. They have good customer service from what I've heard. The success stories with them seem to be hit or miss.
    Stage II WRB WRX Wagon
    Jun 2009
    Parsippany, NJ
    Also, are you using a sandwich adapter?
    Dec 2009
    portland
    yes using a sandwhich adapter. ill try giving them a call on monday. had no problem with my other prosport gauges just the oil pressure one.
    Registered User Prosport Gauges's Avatar
    Sep 2006
    Tampa, Florida
    Did you check the ground to the sender? With the gauge pegging out it indicates an open circuit. So maybe the engine torgue on throttle combined with a loose ground/bad wire is causing the problem.
    As mentioned above you can always call us for tech support so we can get you fixed up asap.
    Registered User lil al's Avatar
    Sep 2009
    baltimore, md
    would the rposport sanwich adapter work for a different brand of gauges? glowshift oil sanchwicha dapter is terrible
    Quote Originally Posted by lil al
    Greddy offers one I've been eying for a while ...
    Registered User Willard's Avatar
    Feb 2009
    Camarillo, CA
    Quote Originally Posted by Prosport Gauges View Post
    Betcha thats the problem. If the sandwich plate is anodized, painted, or hard coated youll have to ground the sending unit.
    Had that same problem with an oil temp gauge.
    2011 Honda CR-Z EX
    Milano Red / Navigation / 6MT
    2009 WRX hatch premium SEM #52 Traded 7/28/11
    Kartboy STS & bushings // RedlineGoods Shifter & E-brake boots // Muffler delete pipe // Window tint //
    Sep 2006
    Tampa, Florida
    Our adapter plate will work as long as the sensors you are using are 1/8th NPT
    Texas, United States
    My Prosport electronic oil pressure gauge reads ~20psi low across the board. I'm going to give you guys a call some time this week and see what we can work out. It's probably a bad sending unit, maybe I you could send me a replacement and I could send the current one back once I get the replacement installed, or can it be recalibrated? It still works, but it's reading 1psi at idle and the mechanical gauge I hooked up was reading 23psi.
    Sep 2006
    Tampa, Florida
    please call us for warranty and return information
    Ryan
    727-572-9011
    Mar 2010
    Quote Originally Posted by scoobidoo View Post
    that's exactly what the prosport gauges look like
