Guages!
Results 1 to 15 of 16
This is a discussion on Guages! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Getting ready to order some gauges and I have a couple of questions. First off, I have a 2005 WRX, ...
    Registered User 2005sti's Avatar
    Jan 2010
    Trinity, NC
    Guages!
    Getting ready to order some gauges and I have a couple of questions. First off, I have a 2005 WRX, no mods at the moment, but going to be Stage 2 shortly. I already know that I am going to purchase an Autometer Boost Gauge and an AEM Wideband for A/F Ratio. I want to buy another gauge, but I do not know which would be the most useful. I also do not know which pod is easier to install, the 3 guage pod that go on the pillar beside the window or the clock gauge pod. So here are my questions...
    1)What should my 3rd gauge be?
    2) Which gauge pod should i get, based on wich is easier to install and which is easier to install the gauges into?
    3) What the easiest way to run the wiring for the gauges?
    Thanks for any help!
    2005 Subaru Impreza WRX - FP 68HTA'd
    2007 Honda Civic Si (Stock) - Traded it for ^^^
    Blobeye Syndicate #728
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    EGT would be my bet.. I like both options of the pillar and the clock pod, I do however lean more to the pillar is a little cleaner.
    third option would be stick with the two gauges and run a cluster pod.
    Lead Wrench @ WTF Tuning, LLC
    Jan 2010
    Trinity, NC
    never thought about the cluster pod.
    I think both gauges are 52mm. Think they would look good there? Not too big?
  5. #4
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by 2005sti View Post
    cluster pod...?
    Yea it replaces the factory black trim around your gauge cluster and puts a gauge pod in the bottom of each corner. So all gauges are readily available at 1 single glance..
  6. #5
    Jan 2010
    Trinity, NC
    Never thought about that one. I love it though. Looks great! Where is the best place to T in for the boost gauge?
  7. #6
    Vez
    Vez is offline
    Registered User Vez's Avatar
    Apr 2006
    Near Philly, PA
    Is an EGT gauge necessary if he's going to get a wideband O2?
    I thought that your first three gauges are usually boost, egt (or wideband O2) and oil pressure. After that it seems to vary a bit. After those, my next three will be oil temperature, volt, and a clock (since there'll be both an a-pillar for 52mm and clock pod for the 60mm...and I really like having a clock).
    Hawk-Eye Alliance #081
    I'm the only person born a Pirate and trained as a Ninja; I sometimes don't get along with myself..
    2007 UGM WRX STI Ltd. #081/800
  8. #7
    Dec 2004
    Medford, Oregon
    I dont know.. I dont run gauges.. My computer tells me
  9. #8
    Jan 2010
    Trinity, NC
    Damn. :P Does anyone know the best place to T in the boost gauge? And the easiet way to wire the gauges. This is assuming im using the cluster 2 gauge pod.
  10. #9
    (Pictures taken from this thread)
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  11. #10
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    Cant see the picture...... but right on top of smaller line coming off the top of the BPV.
    3rd gauge.... oil pressure.
    02-05 clocks are useless (06+ had airbag indicators)
    But with that said... I would look at the clock replacement pod before going with the A-pillar pod.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  12. #11
    Oct 2008
    stephenville,tx
    I would go with a a-pillar pod.
    I have the glowshift apillar with
    boost
    oil pressure
    volt
    very easy to install. I tee'd the vac line for the boost with the BPV. And through the firewall gromet(sp) hole.
    I suggest you or anyone here NOT to but anything glowshift.
    My boost stopped working and is stuck on 6psi and other times at 11psi I have to send back to them to test and replace.
  13. #12
    Jan 2010
    Trinity, NC
    So, how good are the glowshift gauges overall? Accuracy, problems, how long do they last?
  14. #13
    Oct 2008
    stephenville,tx
    I bought the pillar and three gauges for 180.00 from glowshift.
    The accuracy is pretty good only problem I have had has when it was shipped the button that changes the backlight got stuck. All I had to do was twist tje gauge a little bit and it worked. I fixed my boost problem just after work today by doing the same thing. I am not sure how long they last. I have had mine since December 09. I would like to install a killswitch I guess you would call it for when I am driving and night, sometimes tje colord light gives me a headache. Other than that they are good. I'd just say buy others but if tight on cash like I was then glowshift works.
  15. #14
    Jan 2010
    Trinity, NC
    Anyone reccomend any other gauges? I found a package on glowshift for a pillar and 3 gauages for like 179, but would like some other ideas on gauges.
  16. #15
    Registered User Mr.Sub's Avatar
    Feb 2010
    I used glowshift gauges in my Lexus GS300 Na-T application.
    I WOULD NOT use glowshift. I found them to be cheaply made and the boost gauge wasn't very accurate.
