starting issues
Results 1 to 2 of 2
This is a discussion on starting issues within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; has anyone encounter this?i have an 03 at times when you turn the key to start it doesnt do anything.if ...
    Aug 2008
    lexington,ky
    Question starting issues
    has anyone encounter this?i have an 03 at times when you turn the key to start it doesnt do anything.if you keep turn the key it starts.ive had the started tested and its fine,is it a relay issue,or clutch pressure switch?any input would be helpful.
    Remove the driver's side floor mat and see if the problem comes back.
    Does the cruise control work? That's also switched to the clutch pedal (separately, true, but its a clue if it doesn't work).
    Is the battery old? Are the leads secure?
