Results 1 to 9 of 9
This is a discussion on what is this for? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just received my 2005 sti.Imported it from the united states. It came with this hole in the cluster?? does ...
    Feb 2009
    what is this for?
    I just received my 2005 sti.Imported it from the united states. It came with this hole in the cluster?? does anybody know what was suposed to be there? the boost gauge is on the other side. any ideas?
    thanks
    The bezel fitted onto your vehicle is not a Subaru factory piece; it's aftermarket and intended to hold two gauges of the owner's choice.
    Feb 2009
    thanks, what would be the best gauge to put in there? A/F ?
    Registered User tybalt762's Avatar
    Mar 2009
    Reading, PA
    Quote Originally Posted by maurim3 View Post
    If you have boost on the other side, that's what I'd do.
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    That's a small horizontal cup holder.
    Jul 2008
    San Antonio
    Quote Originally Posted by Trainrex View Post
    Damn, I want one now.....
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Oct 2002
    The Old Folks Home
    snortclamf
    --Ray
    Proud owner of a N.E.R.D.
    Not Asian Ying's Avatar
    Jul 2007
    Harrisburg-ish
    Previous owner's morning communte was one heck of a steep descent.
    Registered User jpjester's Avatar
    Apr 2007
    Doylestown PA
    If you already have a Boost Gauge I'd Recommend the Air to Fuel as well. Yet, if you do have a Boost Gauge if it's the small one with the black background (someone help me with the brand). I'd recommend replacing it as those are not exactly accurage.
    As for the A/F Gauge I would highly recommend getting something that is extremly accurate. A little more pricy but down the road it will payoff when tuning. Check out
    Wideband O2 Systems Turbo XS Tuner, NGK AFX, Innovate LM-1, AEM UEGO, Auto Meter Widebands from JSC Speed.
    Previous Subarus:
    2004 Subaru WRX, 18G Deadbolt Zilla setup w/ Supporting Mods
    2009 Subaru WRX Hatchback Stock!
