I have the same mirror for an 09 wrx. I'm gonna assume it is the same function on how to program it. I went through the instructions and havent been able to get it to work. What worked for me was holding down the outer two homelink buttons for about 20-30 seconds until the light blinks. then holding the original opener and the button i wanted to set for a few seconds. this always resulted in the mirror button blinking rapidly then not opening the garage. finally I went to the garage door motor and pressed the reset/learn button which on the two I set was located above the antenna wire. After the door motor light was blinking, I pressed the button I wanted to set, 2-4 times and then it finally worked. Hope this helps, if this is what you already tried, my dealer said if I couldnt get it to work, they would set it up for me for free. So you could check that too.
LinkBack URL
About LinkBacks
