Results 1 to 7 of 7
This is a discussion on Removing trunk badging within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Whats up all..... i decided i want to debadge my trunk. I want to take off the S U B ...
    Registered User Scooby3's Avatar
    Dec 2005
    39° 52′ 14″ N, 75° 23′ 27″ W
    Whats up all..... i decided i want to debadge my trunk. I want to take off the S U B A R U lettering, the subaru logo (pink 'i' badge on its way) the IMPREZA badge and possibly the WRX badge. what is the easiest way to do this without scratching the car? thanks for the help.....
    2004 PSM WRX Kartboy Short Shifter, SPT Cold Air Intake, TurboXS Turboback Exhaust, Cobb AccessPort Stage II
    Blobeye Syndicate #123
    Dirty Crew #123
    stilofugaz
    hay
    im the maneger of the reccon department at Herissonburg Nissan, Im in charg of cleaning the cars, the easy way to take the letters off is by pulling them off, then u will nead a heat gun to worm the glue up, dont use anything that will scrach ur car, use ur fingers not ur nails, dont heat it up too much, the emblume has 2 screws that u nead to take off, but it will leave holes, so i just left it on, hope this helps
    Dec 2005
    awesome.... thanks
    Dirty Crew #123
    Registered User chris227NJ's Avatar
    Mar 2008
    Morris County, NJ
    Talking also
    also, if you don't own a heat gun, there are several glue removing products you can buy (at autozone) that will rub any epoxy or glue off with some elbow grease. i think the one i used is called "Goo-Gone"
    "they call me tq. too quick"
    Feb 2009
    adelaide, AUSTRALIA
    i used a kettle to boil water, waited a minute of 2, poured it over the badges then they peeled off easily. the glue also rubbed of with ease cos of the hot water. good luk
    Registered User 08WRXME's Avatar
    Oct 2008
    York, Maine
    Hair Dryer, dental floss and goo-gone! works great and the hair dryer is safer then a heat gun!
    Dec 2008
    Kenosha
    Also if there is anything left on the paint you can use bug and tar remover to take it off without damaging the paint itself.
