changing wrx gauge cluster colors? where to find bulb condoms?
Results 1 to 13 of 13
This is a discussion on changing wrx gauge cluster colors? where to find bulb condoms? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; ive seen some threads on how to change the colors of the gauge cluster. but does anyone know where to ...
    Jan 2009
    ive seen some threads on how to change the colors of the gauge cluster. but does anyone know where to get the bulb condoms for the lights? and what exact color to get to match the STI. (pink or red) ha <not sure if the red will fade to the STI color or if there is a pink that works> well if anyone can help me out it will be much appreciated.
    thanks
    Registered User Tony_UBAR's Avatar
    Jan 2009
    P-Town
    Switch to LED's
    hey i am not sure where you can get the condoms for them but i would recommend switching to LED lights way brighter and takes less power.. you can get them at superbrightleds.com they have 5 different colors i think.. the led size you want is 94. you can either get a wedge led or get the led built in with the plastic piece that holds the bulb in there.. and there not very expensive at all! i got 10 Red leds (i am hoping that they are gonna look like the STI lights) for only $20.i should be getting them here pretty soon. when i do and put them in i will post some pictures.. but you also go to sand down the plastic sheet that has the numbers and everything on it cause it has a green film on there..
    Jan 2009
    P-Town
    here is a picture of my IS300 gauge lights that i put blue LED's in.. the original color was amber. its a crappy pic but it looks alot better!!!
    Jan 2009
    P-Town
    02Subaru LED light switch
    alright here is a picture of my new lights i just got and put on my suby.. the original color was the stock green. i had to sand the back of the plastic sheet that has all the numbers and markings on it. a total of 8 LED lights will work for the dash and the Air control unit.. i took the pic with me IPhone. but it looks alot better in person!!
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Is the color even...? Doesn't look like it in the pics.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Jan 2009
    P-Town
    yeah the color is pretty even. i think its just the picture. or it could be that i didnt sand down the back good enough..
    Feb 2009
    94 or 74
    Quote Originally Posted by Tony_UBAR View Post
    the led size you want is 94 .
    Was that 94 or 74?
    I tried the "condom" technique a few years back but, the "condoms" kept popping off and didn't provide a true red glow.
    The T 1.5R LEDs with base look like a nice solution esp. for ~$1.79 each.
    Thanks!
    Jan 2009
    P-Town
    it should be 94. The T1.5 is prefect that's what I got and I like them alot. And all u got to do is twist them right in.
    Jan 2009
    The dash looks good, I'm thinking of doing this too. So is there just a thin film of green plastic or tint on the back of the gauges? What grit of sandpaper did you use?
    Jan 2009
    P-Town
    I think I used 200 and then I used some oops or goof off to clean it up. I sanded the whole back of the plastc gauge thing.
    Registered User mikesims17's Avatar
    Apr 2008
    Film over Speedometer
    Did the green film cover the entire back of the cluster or just the odometer? I'm thinking of just changing the color of the the speedometer the RPM's and the gas. Was it a fairly easy process to get the LED's in? or did you have to change each socket to get the LED's to stay in?
    Mike
    Jan 2009
    P-Town
    the green film covered the entire back of it. there also was a small plastic green piece that is in between where it tells you your miles on your car. you just have to pull the one side that doesnt have all the connectors on it up and slide out the piece. its not glued or anything it just sits in there. but thats if you want that area to change color as well..
    Feb 2009
    Excellent! Thanks! I'll order them and look into a cabin air filter. Just found out how simple it is to add one...
    The '02s have the filter compartment but, Subaru didn't install a filter.
