Results 1 to 3 of 3
This is a discussion on 02 to 05 door panels and dash conversion within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Can you straight convert from 02 to 05 door panels and dash and vice versa? It seems simple enough, if ...
    Dec 2008
    Can you straight convert from 02 to 05 door panels and dash and vice versa? It seems simple enough, if the clips are the same then it should work just fine.
    Registered User CJ05's Avatar
    Apr 2008
    North Juarez Mexico (aka El Paso TX)
    If i heard correctly the door panels should swap right out.... the dash, that is a whole other story. If you're trying to swap your bugeye to make it look like the blobeyes (saw other post) and then swap your dash to an 05... might be better to just sell/trade your bugeye and get a blobeye.
    Bugeye Mafia #231 - 2002 WRB - sold Dec 31, 2009
    -Stink-Eye Mob- #173 - 2008 SWP - Returned to TD04 Stage 2 in Jan 2012
    Frmr Blobeye Syndicate #173 - 2005 CGM -sold Sept 15, 2008. I miss my STi
    Proud owner of 99 RS coupe with EJ205 engine and tranny swap.
    Dec 2008
    Thing about the dash is that I believe the lower part of the dash can be swapped very easily if I can get all the parts.
