Floor mat soaking wet, causes?
Results 1 to 14 of 14
This is a discussion on Floor mat soaking wet, causes? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I drive an 02 WRX and lately my driver side floor mat gets soaking wet between drives. This happens whether ...
    Oct 2008
    I drive an 02 WRX and lately my driver side floor mat gets soaking wet between drives. This happens whether it's raining or not, and condensation fills the car overnight. Since it happens even in dry conditions I don't think it's a window leak. Any possibilities?
    M.
    Registered User ssamurai26's Avatar
    Aug 2003
    Japan
    Really horny GF?
    "I am Bullrock, and I have lots and lots of powers"
    へおひってしりつぼめ "There is no use scruntching up your buttocks after a fart"
    Next time you drive do NOT use the A/C or the defroster. What happens then?
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    I was thinking the same thing. Heater core?
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
    Quote Originally Posted by ninefourteener View Post
    Possibly but that'd smell of coolant. Might be condensation from the A/C, or a leaking water line if there is a rear-mounted I/C sprayer reservoir (I doubt this). What's confusing is that it's on the driver's side and not the passenger's.
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    A/C condensation? Leaking weatherseal? Even if it's not raining there could still be some seepage. Try spraying the car in the front windshield area with a garden hose. Take a look inside. Any drips or wetness?
    Registered User silver03's Avatar
    Jul 2003
    10000 Lakes
    leak
    heater lines securely fashioned on the firewall? Have you monitored your coolant level...should this even be a suspect?
    Jun 2008
    Does your car have a sunroof? I have had problems in previous cars where sunroof vents clog and water gets on the pass floor.
    Registered User madmaxwrx's Avatar
    Oct 2008
    mundelien,IL
    i have kind of the same problem but its right behind the passanger seat in my wagon it usually after it rains or its wet in the snow any ideas
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Gentleman do you have clogged AC drain lines? You know the little lines on the firewall next to the downpipe.
    If you use the defroster, your A/c is on. If your drain line is clogged, the condensation must go somewhere.
    If it is clogged, it will leak back.
    Also if you park outside a lot under trees, make sure your windshield cowl is free of built up debris.
    How good are your door seals?
    Also Heater core, but it would be green and sweet smelling.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    May 2007
    Delaware
    Quote Originally Posted by madmaxwrx View Post
    this my issue in my sedan.
    Oct 2008
    mundelien,IL
    Quote Originally Posted by 06wrx4me View Post
    well i park in a garage so the window is not a problem it could be the door seals i can hear the snow crunching? outside while driving and the drain line might be it also how would you get it unclogged and jw how it would affect the floor behind the passenger seat
    Sep 2006
    lots seem to have this problem
    Anyone find a solution to this problem? It seems common.
    I have a similar problem - my car smells musty/moldy when it rains and the carpet is damp (no leaks in the doors). If I make a point to use the defroster whenever it's raining out, no smell. How's it getting in there?
    Nov 2008
    Has anyone tried sitting in the car while someone else squirts it down? It may take awhile and be boring but you may be able to rule out the doors.
