Alternator Mod: 1/2 volt more for $1!!
Results 1 to 12 of 12
This is a discussion on Alternator Mod: 1/2 volt more for
!! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Me and a couple of guys on NASIOC decided to use an old GM Bosch alt mod.Basiclly it rquires you ...
    Moderator Donkey's Avatar
    Da boonies,Va
    Me and a couple of guys on NASIOC decided to use an old GM Bosch alt mod.Basiclly it rquires you to splice a diode in into the alternator reference line.I used a 1N4004 diode and am seeing 14.8-14.7v at idle minium load compared to 13.8-14.2v I was normally getting.
    Alternator messin' with performance? - NASIOC
    2002 FORESTER S
    1998 FORESTER S
    Moderator timber's Avatar
    St. George, Ut.
    This looks very interesting...is there any definitive improvement in driveabilty/performance?
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Da boonies,Va
    Quote Originally Posted by timber View Post
    The car does "feel" better but I hate using my butt dyno as it can be biased. Theorecticly the car should run better.More voltage to the coil packs,fuel pump,injectors,lights,stereo..blah,blah.Some people are only seeing 13.6-13.8 max but that must be a grounding issue.I do run a ground kit.
    2002 FORESTER S
    1998 FORESTER S
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    St. George, Ut.
    I'm not sure I'll pick up twenty hp, but if it stops my interior lights from pulsing with my (stock) stereo on, I would be happy. Thanks for the heads up, Donkey.
    "Never Launched"
    Dougie
    -5,000 posts
    Da boonies,Va
    I think the 20hp was probably a special circumstance.Some of the 02-03's had lower voltage than most not to metion some grounding problems(the cause probably).It was pretty warm here last night and on the way home I consistanly saw 14.2v even with a full load.Usually I would be seeing 13.6-13-8v with just my lights.Once it starts to get colder the voltage will go alittle higher.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2008
    Great idea, nice cheap mod!
    Oct 2005
    Ocean Grove, NJ
    interesting
    I'm wondering if doing this and a grounding kit would help clear the "lope" out of my idle.
    Registered User whiterex19's Avatar
    Apr 2008
    middletown RI
    when i bought my 06 wrx it came with hid"s and i thought something was wrong with them cause one side would flicker and sometimes go out. Do u think this could be caused by voltage issues because now that its an avg of 60 out here in rhode island they work perfect
    Da boonies,Va
    Quote Originally Posted by whiterex19 View Post
    Couldn't tell ya.You would have to have tested the voltage going to the ballast at the time of the problem to confirm.Plus you had one working and one not.Sounds lika a ballast/bad connection issue.
    2002 FORESTER S
    1998 FORESTER S
    Registered User treq18's Avatar
    Aug 2008
    SLC, UT
    does anyone have pictures of what line they are connecting the diode into? i read the other thread but am alittle lost with out pictures. i would like to try and do the diode and grounding kit sometime this week if i have time.
    friends don't let friends ride stock...
    Gilly Monster quote:" if you start driving like an asshat we will demote you to Civic tuner status."
    Registered User djerickd's Avatar
    Jun 2001
    Tampa, FL
    This works awesome!
    SnowMann Tuned
    special thanks to:
    www.Aquamist.co.uk
