Do you have a multimeter to test the electrical signal from the sender to the gauge? If not, I would check all connections, clean and reland your ground connection (if chassis ground) and test the setup again, seeing if conditions improve.
There could be a loose connection, which when it warms up, parts expand and make them even more loose. Idle is when your motor vibrates the most, with larger lower frequency movements.
LinkBack URL
About LinkBacks
