im F'ed
Results 1 to 12 of 12
This is a discussion on im F'ed within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i tried taking out the galley plug and stripped the hex out on it...got the right size tools and everything...just ...
    Registered User W0R7Xsubi's Avatar
    Nov 2006
    New York
    im F'ed
    i tried taking out the galley plug and stripped the hex out on it...got the right size tools and everything...just stripped out
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by W0R7Xsubi View Post
    I'm sure there are other galley plugs to be had...
    Dealership could probably hook you up for a couple bucks.
    Nov 2006
    New York
    no i tried takin out the plug so i can put the one for the gauges in the oem one that was on the car is stripped
    Aug 2002
    Virginia Beach, VA
    Not the end of the world. It can be drilled/tapped. I would take it to either the dealership or an aftermarket performance shop and describe your problem. It's a relatively common occurrence, albeit in a difficult to reach location.
    Nov 2006
    New York
    i had it on there good....had a 10inch extention and it just stripped
    Nov 2006
    New York
    i didnt strip the threds...i stripped the 5/16" hex on the plug tryin to get it out...
    Aug 2002
    Virginia Beach, VA
    There's your problem. 99% of the bolts on these cars are metric...english units will not fit properly. It's an 8mm hex socket...
    Nov 2006
    New York
    well thats what the instructions said...what now? r there other options?
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by Timdog1650 View Post
    Post number 4.
    Registered User BlueSubaru's Avatar
    May 2008
    Prospect Heights IL.
    Im not sure if you can get at it but maybe try hammering a torx bit into it that will fit real tight,this has worked for me in the past but for a different application, if it doesnt work.... reply #4?
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    Clear out everything around it as much as possible and use pliers.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Registered User dspowersports's Avatar
    Jun 2007
    Milwaukee, WI
    Another option would be to use the one at the front of the motor where the OEM oil pressure sendor is located. You would have to remove the original though and use a resistor to turn off your dummy light.
    Or get the sandwich spacer for your oil filter and use the aftermarket gauge sender on there. Prosport makes them for around $40 bucks.
