Heres the trunk mat
http://www.subarupartsforyou.com/cp_...&model=Impreza
If you look hard enough you might be able to find the plate on the same site, if not than a stealership is probably your best bet... I got my mats from here
SubaruWRXParts.com
This is a discussion on ecu and mat differences throughout the years within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; so i just got a 2004 wrx. and i need the plastic as well as metal housing that came on ...
so i just got a 2004 wrx. and i need the plastic as well as metal housing that came on the ecu, since i removed the utec. i also need new floor mats and trunk mat cuz they are trashed. does anyone know if these parts are the same throughout the gens or does the size/shape of them change. thanks.
Heres the trunk mat
SubaruWRXParts.com
"M3 drivers have no friends..." - Jeremy Clarkson
"If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
SubaruParts.com - Your #1 Source for OEM Parts and Accessories has breakdowns of every part in the car with part numbers, your bound to find it there if you haven't already.
