which boost guage did u get? the blue racer or the bf series and i know theres another one but if u don't have the blue racer series you need a controller....if u got that them its real simple to install.....
first decide where you want the controller to be located...some people put it under the steering wheel...others like my self in the arm rest....idk about putting it under the steering wheel but for the arm rest you will need to extend the lines.....ok this is how you do it....take the clock pod out....the conections to the clock is the wires you will need for the controller....the clock will tell you which wire is what and defi will tell you which wire you need to connect....there will be 4 wires.....i suggest not using taps but actually soldering the connections onto the wires....i used taps and found that after a while they don't seem to hold the connection....
once you connect the controller harness....then wire the boost sensor....find a place that you would like the senor sit in the car....make sure that its close to the BPV or by pass valve (located on the intercooler)....i think i used a screw holding down the tube for the A/C....then use the T flange and cut the BPVs vaccume line and tap into that.....connect the hose from the sensor to the T flange....the wire from the senor connects to the controller....there will be a wire that came with the controller that connects to the boost guage....make sure you put the wires in the right spots!!!!! read the directions becuase you can blow fuses if you don't
LinkBack URL
About LinkBacks
