Other then the fact that you have to completely remove the center counsel. The clips just need a flat edge screwdriver on the center piece, then when it pops out the whole assembly comes out. Be carefull removing as one piece or folding it carefully, its sprayed wiht a type of plastic in the center areas and it will kink, so it will look like **** when/IF you put it back in. A friend helps.
LinkBack URL
About LinkBacks
