05 STi steering wheel?
Results 1 to 7 of 7
This is a discussion on 05 STi steering wheel? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey guys what would it take to be able to replace an 04 STi steering wheel with an 05 STi ...
    Registered User Lbleiweiss's Avatar
    Barrington, IL
    Hey guys what would it take to be able to replace an 04 STi steering wheel with an 05 STi steering wheel? Do they just swap right out?
    Thanks!
    Lowell
    Blob-Eye Syndicate #121 MY04 Stage 1 WRB STi
    Dirty Crew #89 like it dirty? Dirty Thread!
    "0-60 Faster Than Your First Sexual Experience!"
    Gettin Sideways At El Mirage
    The Best Video YouTube's Ever Seen!
    Courtesy of SomeGuy 217 Productions
    Barrington, IL
    Cmon guys I know someone knows the answer!
    Registered User DentGuy05's Avatar
    Jul 2007
    Algonquin IL
    what is the difference between the two?
    Wingl3ss @lliance #18
    Blob-Eye Syndicate #71
    Barrington, IL
    Thats the 05
    Thats the 04
    04 looks weird IMHO.
    Registered User AlexKey's Avatar
    Apr 2008
    Kiev, Ukraine
    Lightbulb
    It will fit perfectly
    Okay, a little "how to" I think it might help ))
    The very first thing is that you have to disconnect the negative wire from battery!!! Wait a few minutes and then you can push the brake pedal a few times. And finally you might want the airbag fuse be taken out. Just in case
    Yeah the wheels and the steering wheel has to be looking stright
    Unscrew two bolts on the back sides of the steering wheel, they are located at 3:00 and at 9:00. Then carefully take the airbag out. Look for the harness plugs. There might be a plug for the airbag (the one with green clip) and a plug for cruise control. Unplug them all. Next step is to loose the nut in the center (it is 17mm). When you loose it leave a nut on the top of carving so the wheel won't hit you when it comes off. Just pull the wheel. Remeber to pull it stright towards to you. Do not spin it and do not bend it! When it comes do the back assembly with the new wheel. Another thing to remeber: there are two arrows (one on the yellow sticker and one on the wheel back cover) that are had to be in one line! Make sure you plug in all the harness plugs and tight all the bolts enough. Put the airbag fuse back. Connect the negative wire back on the battery. If you have an alarm installed on your car, then keep the remote control in your hand before connecting the wire, cause the alarm will start shouting and yelling
    Well. You're done. Enjoy the beauty!
    Sorry if my English isn't good enough, still I think that everything is good to understand
    P.S. look for the PM ))
    Best regards!
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    I like the '04 better
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Apr 2008
    Kiev, Ukraine
    Cool
    Quote Originally Posted by Pavia View Post
    Me to
    But somebody likes Hondas more than Subaru
    It's just a matter of taste
    Best regards!
