2005 Subaru WRX Poor FM reception
Results 1 to 10 of 10
This is a discussion on 2005 Subaru WRX Poor FM reception within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey guys I have a issue if you with my newer vehicle I got. I installed an aftermarket Kenwood head ...
    Feb 2008
    NE PA
    Hey guys I have a issue if you with my newer vehicle I got. I installed an aftermarket Kenwood head unit along with an Alpine MRP-M350 amplifier along with 2 10" Alpine Type-R subs. I installed this into a 2005 Subaru WRX and everything works perfectly except for the radio. I am getting no AM reception at all and poor reception on the FM stations. The prior stock head unit worked perfectly, but didn't have any place for my subs to get hooked up through RCA. It's my understanding that the wire for the power antenna in the back windows is powered by the white wire and the blue antenna wire needs to be hooked up to that and thats the way I have it now. Is there anyway I could fix this issue at all or does anyone have any tips for me to solve this issue? Could it possibly be the head unit itself? Please help me out if you could!
    Thanks,
    Jeff
    Nov 2006
    South Jersey
    Quote Originally Posted by iceman33 View Post
    Thanks,
    Jeff
    if it was that tight for the rca's its possible u knocked loose the antena cable when u put the head back in. ive done that in the past with tight installs. I know its silly, but did you pull it back out and check it?
    Registered User adizzle02's Avatar
    Mar 2008
    Sandy Utah
    Thanks,
    Jeff
    How did you connect the wiring(solder or crimp connector)? Also did you use an aftermarket wiring harness(pleaee say yes ) or is your factory radio plug been cut off? I would double check the power antenna wire(white) from the car wiring and the blue wire from the aftermarket harness to make sure that there is a good conection. I would also check the antenna wire itself. Not sure if the suby is like this but there are a lot of cars that have an extension piece thats lower down in the dash and sometimes if the antenna cable is short it can come unplugged.
    VF39'd and Clark Tuned
    BugEyeMafia #176
    Basshead Member #3
    Feb 2008
    NE PA
    Hey all the wires are soldered together and I do have an aftermarket wiring harness attached to it lol. The antenna is in fact seated in their quite well because it doesn't just slide out when you try removing it and everything is secure back there. So that is why I am having some trouble figuring this one out. But thanks for the info!
    Quote Originally Posted by adizzle02 View Post
    Mar 2008
    Sandy Utah
    sorry I had to ask..you wouldnt believe some of the messed up stuff i saw when i was installing car audio..... Man thats a head scratcher.. Is the radio a new one?
    BugEyeMafia #176
    Basshead Member #3
    Feb 2008
    NE PA
    Lol it's no issue at all. I had this head unit previously installed on a 2000 Ford Ranger for 3 years. its a kenwood head unit. The thing I can't understand is that the stock player when I got the vehicle had the radio working perfectly. But a friend of mine had a kenwood and after a few months his started having an issue with the radio as well. So I always was a fan of alpine so I may just look into a new had unit to see if it corrects the problem.
    Mar 2008
    Sandy Utah
    Ahhhhh gotcha... i Love alpine thats all ive ever ran in my cars for head units. that is pretty weird with the kenwod tho. I wonder is a solder came loose on the antenna piece inside the radio
    BugEyeMafia #176
    Basshead Member #3
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    I know the 06 wrx's use a powered antenna and the "power" wire must be hooked up on the deck harness.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User natedawg9640's Avatar
    Apr 2006
    Fox cities, WI
    if you have tint it tends to affect it a little too... prolly not to any sort of extreme though... i noticed a difference when i tinted mine...
    yup
    Feb 2008
    NE PA
    Hey guys just to give you an update, I took my vehicle to a local audio install shop and the issue is solved! It turns out that the power antenna wire on the head unit was not supply enough or possibly any power at all. So we tapped into the blue/white wire that is attached to the signal wire to the amp and instant success. I do appreciate all the help and I'm off to wash the vehicle! Thanks so much again!
    Jeff
