im pretty sure that they just unscrew and then you can put pretty much anyone that u want on it as long as the threads match up
This is a discussion on shift knob change? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; hi, I have 2003 auto, as seen in avatar. it has stock shifter. i would like to change the shifter ...
i would like to change the shifter head.
Has anyone done this. and what did you uses?how? thanks
1) what did you use
2) how
New England F4 WOLF
2007 WRB WRX Limited SOLD
2008 QSM Legacy Spec.B
thank you, have good day
New England F4 WOLF
yep. it should be easy to just unscrew it. just make sure you dont put too much force on the shifter assembly (the metal rod that goes down into the car) but i dont think that should be the case. if you just turn, it should come off. all you need is a new knob![]()
