Component speaker wiring
Results 1 to 2 of 2
This is a discussion on Component speaker wiring within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; so installing components from stock setup (2004) do i need the metra connectors or can i just cut the wire ...
    Registered User corybb's Avatar
    Cape Girardeau, MO
    do i need the metra connectors or can i just cut the wire before the harness and use those wires?
    Also can the new tweeter use the existing wires to the stock tweeter or should new leads be ran from the crossover?
    Nov 2006
    around
    get an amp and use better, larger gauge speaker wire for the speakers from the crossover and from the amp. If you insist on running the components on the stock head unit, you could use the stock wiring, but it may actually sound worse than the stock speakers because the aftermarket components are made to be run on a higher power source.
