Gauge illumination: where to tag it?
Results 1 to 15 of 15
This is a discussion on Gauge illumination: where to tag it? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Well, I'm quite disappointed in myself. I cannot seem to find a wire that actually increases voltage on brightness rotation, ...
    May 2007
    behind the wheel
    Well, I'm quite disappointed in myself. I cannot seem to find a wire that actually increases voltage on brightness rotation, and decreases voltage on dimming rotation of the dash lights..
    Everything I find is either Violet or Orange/White. Violet seems to remain constant, and the Orange/White increases voltage as you DIM; this is opposite of what i need..
    Where are you guys that run aftermarket gauges (that also connect the illumination) tagging the Illumination wiring? I've had mine on IGN source, and want to change it, since they're so damned bright at night
    Any help is appreciated..
    Thanks
    Rogan o_0
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    If you tap into the dimmer..... you can dim the aftermarket gauges to a reasonable level, but then your factory gauges will be almost invisible.
    I installed a "stealth" switch into me center console.... Directly wired into the power supply for the lighting in all 9 of my gauges. Turn it off, and poof, back to stock (looks that way from the outside anyway)
    I actually did it to detract attention from the officials... late at night... maybe a beer or two in my system.... hot car..... just don't need the hassle, you know?.
    However, there have been times where it was foggy out, and the gauges just caused a crazy glare, so I use my switch then too.
    Just a suggestion.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
    May 2007
    behind the wheel
    yours are EXTREMELY bright, jusdging by your avatar
    I am not looking to actually switch them "off", just dim them down.. I've got LEDs to go in the cluster, too, so once I get those in, they should be about as bright as the gauges... But I STILL want to dim them, as they are still way too bright.. I know there has to be a way to make this work...
    Rogan o_0
    Mar 2006
    SLC area
    I still think if you tag it to the factory dimmer, your gauges will dim, but your factory illumination with be invisible.
    With that, you can use the same technique as I did, but instead of an on/off switch, buy a rheostat (sp?) instead.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Factory boost gauge with illum wire is behind the radio, tap in there.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    May 2007
    behind the wheel
    the only illumination wire i could find behind the radio was ORANGE/WHITE..
    will cluster dimmed, it reads 12V. with cluster bright, it reads 3V..
    I tried tagging that wire, but the aftermarket gauges work opposite of the cluster now..
    Jeremy, do you know WHICH WIRE? Who makes the factory gauge, Omori?
    Rogan o_0
    Jun 2006
    Nor Cal
    This sounds very odd Rick, is your cluster/wiring stock? The factory gauge is NOT made by Omori. Yet my Omori is the exact same brightness as the factory cluster and dims perfectly with the dimmer. If this were normal, I would have thought more people would have had this issue by now
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    May 2007
    behind the wheel
    Quote Originally Posted by 06wrx4me View Post
    all my wiring is OE, with the exception of these additional gauges.
    Do you know WHICH wire, behind the radio, is tapped for illumination? I'd appreciate it if you could share that info
    Rogan o_0
    Jun 2006
    Nor Cal
    I believe its the violet wire Rick. I think I tapped into the foglight switch wire for illumination. Even if you dont have fog lights the wiring is there.
    http://www.scoobymods.com/forums/sho...light=prosport
    Hell or maybe I didn't lol its been 2 years, coulda used the violet in the factory boost gauge area.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    May 2007
    behind the wheel
    well, i had foglights.. but the FMIC piping forced me to remove. BAH..
    I'll check your supplied link! Thanks.
    Rogan o_0
    May 2007
    behind the wheel
    I called prosport..
    "Sorry, the gauges are surface-mounted LED, therefor not 'dimmable'..
    Bummer... oh well!
    So I ordered 2 more (Volt, Fuel Pressure) haha
    Rogan o_0
    Registered User Destros's Avatar
    Apr 2007
    Springfield, VA.
    I've got my gauges where my clock was, moved my clock to the fuse access pocket, and tapped power, ground, and illumination off of my clock wires. Put in two inline fuses and it works perfectly. No wire searching hehe. I used a wiring diagram though. Anytime you ever do anything electrical, USE A WIRING DIAGRAM. Nothing is left up to question.
    -created in the ominous shadow of The Great Vassar-
    Blobeye Syndicate #Eleventy-Seven
    Apr 2007
    Springfield, VA.
    The reason the your gauge dims is because it runs a similar circuit as the cluster does. The clock, on the other hand is wired to have only two settings. Day and night. Get a wiring diagram. Let me know if you need one...
    May 2007
    behind the wheel
    Quote Originally Posted by Destros View Post
    old thread.
    And I have wiring diagrams.
    Rogan o_0
    May 2007
    behind the wheel
    re-read the posts. It does NOT dim.
    The wirig diagram I have is the FSM.
    Rogan o_0
