Results 1 to 5 of 5
This is a discussion on 6 disc changer/navigation system within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i was wondering if you can put a navigation system or 6 disc changer in if the car has a ...
    Oct 2007
    nc
    i was wondering if you can put a navigation system or 6 disc changer in if the car has a one disc player
    thanks
    Registered User Spincycle's Avatar
    Jul 2007
    Janesville, WI
    Quote Originally Posted by gern worm View Post
    thanks
    I am not sure I understand the question, do you mean a single DIN deck? Do you mean aftermarket or a OEM deck?
    Oct 2007
    nc
    if i have this can i go to this
    Jul 2007
    Janesville, WI
    Yes, you should be able to, the only problem you might have is the wire harness, but I believe that they are the same harness from like 02-07, so basically just need the OEM deck, and you should be all set as long as it includes the mounting brackets.
    Oct 2007
    nc
    alright
    thanks dude
