Moved to Cockpit and Cabin
This is a discussion on Adding a siren, wiring question... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I am adding a siren to my 2003 WRX and was looking for input on wiring. I am confused where ...
I am adding a siren to my 2003 WRX and was looking for input on wiring. I am confused where to get these power connections:
Red Lead: Connect the red wire from the amplifier to positive 12VDC. It is strongly recommended that you connect to a 12VDC source that is present only when the vehicle ignition is in the on position. A power relay may also be used. Be sure to use a minimum size #16 AWG wire.
Yellow lead: Connect to +12VDC through a switched power supply (possibly iginition). This will turn the siren on and off. Be sure to use a minimum size #18AWG wire
Orange Lead: This lead supplies power for the backlighting of the siren. Connect it to +12VDC from the dash lights, parking lights or other switched source. Be sure to use a minimum size #18AWG wire.
Could these all be taken from the same source? What would be the best place to pull power off for these wires? I could use any help you guys could give.
Thank you!
"Never Launched"![]()
Dougie - Founder, 250,000 mile club
-5,000 posts
where does the siren go?
The siren (control/switch box) goes in the interior. I am thinking about attaching it to the vertical wall of center console on the passenger side (footwell). I was thinking about taking the power for the yellow and orange off of the lighter/outlet since it's switched and close by. I just don't know about taking the main power (red wire) off that also or of there is a better place to get those power. I will have a low power device (led warning lights) plugged into the lighter/outlet.
The easiest way for a direct power line might just be to run a fused line right off of the battery and through the firewall grommet.
-5,000 posts
I don't know why it sas that the main power should be switched as well (ignition). I hooked it up to a battery and it will not function with just the red and black hooked to the battery. The yellow must also be hooked up to the positive. I think I will just pull power off the battery for the red and put the other two to the lighter power. Does this seem like it will cause any problems?
