ok, should have come with installation directions, but if not, here goes..........(if its anything like mine)
Take the harness adapter(the harness peice with 3 connectors), connect the 2 connectors in btw the ignition and engine side of the ignition connector, connect the other side of the connector to the timer, run the gray wire with the male bullet style connector and connect it to the female
bullet connector wire with one end thats just a bare wire(well, with coating on it), take the red splice connector, put the gray bare wire end in the one side with the stop in it(its the one side that doesnt allow the wire to go all the way through) then run it to your parking brake, in btw the parking brake switch and the actual e-brake(its a green/white wire on my year model, 05, but its fairly obvious), close the splicer completely and lock it so it splices the 2 wires in parallel, then just mount the timer with the included double sided 3M mounting tape........ ****..... stuff..... best place is on the underside of the steering column cover(at least thats where i have mine, nice n hidden, and it makes my crotch glow! ADDED BONUS!) anyways, any other questions, just ask
LinkBack URL
About LinkBacks
