Results 1 to 8 of 8
This is a discussion on Installing amp and subs within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I will be installing my amp and subs and am wondering where I can feed the power cable from the ...
    Registered User NdN Ninja's Avatar
    Feb 2007
    UT
    I will be installing my amp and subs and am wondering where I can feed the power cable from the battery to the amp. On my last vehicle I used the firewall, is there one I could feed it through in the '04 wrx? Pics would help. Also, suggestion would be good for the ground cable as well.
    Registered User bikefreax's Avatar
    Jan 2006
    Columbia
    I fed mine through the firewall. There is a grommet right above the pedals. As for the ground I went to the seat bolts.
    '05 WRX Wagon San Remo Red, Stage ?????????????
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    +1 and +1. I think I used something like that for the ground.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Apr 2007
    8000' up in Colorado
    +2 and +2
    Scott
    Feb 2007
    UT
    Quote Originally Posted by bikefreax View Post
    Any chance of getting a picture?
    Registered User scoobyroo's Avatar
    Just lift up the carpet and you'll find one.
    Curent: 1988 VW Golf Cabby
    6-8 months: 2006 JPB STi
    Registered User bluerex47's Avatar
    Jun 2004
    ohio/texas
    don't even have to lift the carpet. My firewall hole had a little black piece over it (don't know the material, maybe a vinyl type covering with foam behind it). I just popped that out of the way then put a hole in the rubber grommet.
    I don't have a pic, but crawl up under your clutch pedal, and you should see it looking you in the face.
    As far as ground, I used a bolt that was in the trunk. Just make sure you strap down that sub box.
    - chris
    04 wrx, 04 corvette, 66 GTO
    ACT installed at 36k...new Gears at 44k...
    Feb 2007
    UT
    ^ haha word up on the box bein strapped in
    thanks for the help fellas
