Results 1 to 6 of 6
This is a discussion on turbo timer question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; basic question: how important is a turbo timer?...
    Registered User wagon_guy808's Avatar
    Sep 2007
    on the Big Island!
    sure as hell ain't your grandma's wagon
    Registered User wrxisthebest's Avatar
    Jun 2007
    Angels Camp, CA
    some say needed.....some say not...but i bet this site will say not needed
    other sites may say somethin diff, i personally bout my car with one!!
    SPONSORS for Rally:AMSOIL, Livewire Energy, Six-feet deep clothing, ARS(Aluminum Rapid Shelters), and FatHeads Eyewear.
    Moderator
    Jul 2003
    Maryland
    It is not needed at all. The turbo is water/coolant and oil cooled. As long as you arent hitting full boost going into your driveway and shutting the car off you should have no problems.
    I generally take the last 4-5 mins of my commute rather easy to let things cool down a bit.
    If it was needed every stock 02-07 wrx with over 10k miles would have blown turbos by now.
    Registered User wrbbugeye02's Avatar
    Sep 2007
    NJ
    Its preventative maintenance is all it doesn't hurt 20 seconds is all it takes
    JDMSTIBUGEYE
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by wrbbugeye02 View Post
    Or you could save the money...save wear and tear...save install time...and save addding un-needed electronics to an already highly electronic vehicle.
    To each their own.
    May 2007
    NY
    dont need it unless you have to have it. i have an FP green thats just oil cooled so i run one, yet i only have it set for 30 seconds and i just drive easy for 5 minutes when i know im going to be somewhere. i could probably not even run one and be ok.
