1st time installing AMP + Subs
Results 1 to 4 of 4
This is a discussion on 1st time installing AMP + Subs within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; So I'm installing an amp + subs to my 04 subby wrx that has a new stereo in it(The thing ...
    Sep 2007
    So I'm installing an amp + subs to my 04 subby wrx that has a new stereo in it(The thing that controls what you are listening to).
    1st, is it hard to do this?
    2nd, are there any instructions or should it come with the amp?
    Thanks in advance
    Registered User Spincycle's Avatar
    Jul 2007
    Janesville, WI
    Quote Originally Posted by Jubert69 View Post
    Thanks in advance
    It really depends on what you plan to get, there are some sub boxes that have an amp built in, or you can get a box, then a separate amp. For the best sound you will want to get a separate AMP and Box with Subs. Basically you will need to run the preouts from your head unit (stereo) to your AMP and then also run the Remote wire from your head unit also. Then from the battery you will need to connect the main power line and run it to the AMP. the Ground is all that is left and that must be grounded, I usually ground it right next to the AMP/Sub Box. Be sure to use the proper size wire for the power you are pushing to ensure no fires, also be sure to install a fuse within 18" of the batter wire you connect for the positive lead.
    Sep 2005
    Los Angeles, CA
    It's pretty simple and straightforward, but i'll be glad to help you along with any questions you have along the way. I made a pretty decent setup in my car, i think theres a thread on this site somewhere.
    The only instruction that the amp will come with tell you how to hook up the subs and speakers to get the proper impedance and wattage. Everything else you need to design.
    "You may say the grill is ugly...but thats ok...you wont see it when your behind me"
    Hawk-Eye alliance #004
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Good advice here...I'd like to reinforce what spincycle said; it's important to use the proper gauge wire for the amperage that you're pushing, fusing, and make your ground connection with a short piece of wire to somewhere close. Otherwise a ground wire can try to act like an antenna, and all sorts of weird things can happen.
    Also disconnect the ground to your car's battery while working on this stuff.
    If these concepts are unfamiliar to you, you might want to get some help from someone for your first Amp install. There's not much to wiring the subs into the amp.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
